jammed window!!!
Old Aug 18, 2000 | 08:32 PM
della's Avatar
New Member
Default jammed window!!!
...such a little thing, but so annoying. My driver side window seems to be jammed.
The window does not respond to the automatic button, nor does it do its half-inch up/down action when you open and close the door. The passenger side window works fine.
What's odd is that I had the same problem a while back. I open/slammed the door and everything was back to normal. Then, like months later (ie, now), it is not working. And, no amount of door slamming has un-jammed the window.
Anyone know some tricks to get it working again? Shorting a fuse? Banging the door in a specific place, etc, etc?
Sadly, the forum search engine is down...
All/any help would be greatly appreciated.
Thanks!
Jason
Old Aug 18, 2000 | 08:37 PM
gtt's Avatar
gtt
Default Have you tried opening/closing the window using the key in the drivers door?
<p><img src="http://www.goodmangraphic.com/images/ttmini3.jpg">
Old Aug 18, 2000 | 08:39 PM
NexxTT's Avatar
Senior Member
Default Reprogram it yourself...fix is maybe page 76 or 96 in your manual...
sorry...can't use search right now.
Old Aug 18, 2000 | 10:08 PM
PanTTher's Avatar
It may be a bad electrical or intermittent connection. Have the dealer diagnose it.
Old Aug 18, 2000 | 11:23 PM
Lloyd of the Rings's Avatar
Default RT(F)M!! Page 70....(more)
1) Closethe window completely by lifting the power window switch and holding
2) Release the switch and then lift it again for a second<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/keyfob.jpg">
"The key to having fun"
ChrisTTopher Lloyd
2001 225 TTQ coupe Silver/Ebony
Premium package, Audio package, Navigation System
Old Aug 19, 2000 | 01:51 AM
Rik's Avatar
Rik
New Member
True - if this DNW then you have a loose connection IMHO
Old Aug 19, 2000 | 09:17 AM
Just Plain Cliff's Avatar
Watch that acronym, Chris! Remember the choas I caused last time I posted it. ;-)
Old Aug 19, 2000 | 11:37 AM
Default The "F" in parantheses is for "Cliff"; just for you!! ;-)
ChrisTTopher Lloyd
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 19, 2000 | 11:39 AM
Default Oops, I meant "CliFF" of course.
ChrisTTopher Lloyd
Old Oct 11, 2000 | 03:53 PM
TRTT's Avatar
New Member
Default Re: jammed window!!!
Hello Della, my name is Tim and I had the same problem you do. I
tried the fix that someone else recommended, which is from the A6 FAQ,
of rolling the window all the way up, releasing the switch, and then
holding it again for 1 second. This did not work for me though, so I
tried something else.
This is what I did, and it worked.
I rolled the window all the way up, and while still holding the button
in the up position, I shut off the ignition and then released the window
button. When I turned the ignition back on, the window worked fine.
I don't know if you've had this problem fixed yet, but hopefully this
helps you out.
Best regards, Tim M.
leveTTe
Feb 25, 2010 04:21 PM
heinzboy57
Dec 2, 2008 02:51 PM
DRAGON88
Oct 31, 2005 02:36 PM
Badd TT Bone
Mar 3, 2005 05:46 AM
kent@thething.org
Dec 7, 2002 06:24 PM
