Can't seem to get my timing retard logs to work. I've STFA and have the VAG-COM label file for the
Old Nov 2, 2006 | 09:23 AM
JonRS4's Avatar
Default Can't seem to get my timing retard logs to work. I've STFA and have the VAG-COM label file for the
AEB engine. The archives suggest Group 020 and the label file suggests groups 013,014,015. None of them give me a reading. I just get zeros, 1s or NAs. Group 020 just gives AC information and not timing at all so I guess codes are engine specific.
Any ideas? The logging works for most everything else. I get block 032 fuel trims, MAF reading etc.
Called VAG-COM and they just say to follow the label file.
Thanks for your help!
Tim
'1998.5 A4 1.8T QM
K04 PC-16
Old Nov 2, 2006 | 09:46 AM
illbill's Avatar
Dont worry about the block labels, mine are always wrong too. Timing Retard is block 020
Old Nov 2, 2006 | 09:57 AM
JonRS4's Avatar
Default That's what I thought too but my block 020 gives speed, selector lever, AC Mode and AC status.
That's exactly what the VAGCOM label file for the AEB says it should be. When I talked to VAGCOM they said every engine was different. That certainly wasn't the impression I got following the posts here.
Old Nov 2, 2006 | 10:12 AM
illbill's Avatar
Default what about the actual data spit out to the log, are they numbers between 0 and 15?
I get the same erroneous column headings as you, but the actual values and units are correct.
<img src="http://pictureposter.audiworld.com/38975/block020.jpg">
Old Nov 2, 2006 | 10:17 AM
JonRS4's Avatar
Dunno.....I never logged it given the funky headings. I'll try tongiht. Thanks!
MainelyA8
11
Oct 15, 2019 12:30 PM
tozoM8
VAG-COM Discussion
Sep 17, 2005 08:42 AM
Don@STaSIS
Audi Original "S" Cars
10
Jun 28, 2005 10:41 AM
john s
Feb 4, 2002 08:48 AM
got_root?
Nov 11, 2001 05:51 PM
