Hey shep i vaged the car for readings and in idle it says 0.0 isnt between 2.5-4
Old Nov 3, 2006 | 08:10 AM
mattarios2's Avatar
Member
Default Hey shep i vaged the car for readings and in idle it says 0.0 isnt between 2.5-4
no matter if i rev or drive or idle it says 0.0 you think the plug may have come undone that connects to the maf?
Old Nov 3, 2006 | 08:14 AM
Shard7's Avatar
Yup, either the MAF isn't connected or it's dead
Old Nov 3, 2006 | 08:15 AM
mattarios2's Avatar
Member
alright imma see if its connected
Old Nov 3, 2006 | 08:21 AM
Shep 1.8T's Avatar
Member
Default your maf is un plugged..
interestingly enough you can drive without a MAF, the ECU will just calculate fake MAF values based on the throttle position sensor to run the fuel Maps off of.
Old Nov 3, 2006 | 08:30 AM
Shep 1.8T's Avatar
Member
also how are the MAF wires? any of them look disconnected/broken etc?
Old Nov 3, 2006 | 11:39 AM
Shep 1.8T's Avatar
Member
well? any updates ?
Old Nov 3, 2006 | 07:43 PM
mattarios2's Avatar
Member
Default thanks so much shep, the maf was disconnected, don't know how it happened
but it happened, thanks again shep
Old Nov 4, 2006 | 08:19 AM
Shep 1.8T's Avatar
Member
no problem man, so everything is running correctly?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 4, 2006 | 10:20 AM
mattarios2's Avatar
Member
Default i've driven about 45 miles and no cel, did wot from 2nd and 3rd like you said
logs look fine, the only thing i notice is, now when the car is cold, and i turn it on the rpms jump to like 1700 then drop to about 12 then once its been a min it drops to the normal 800. It never used to jump to the initial 1700 at the start, my dads a6 always did, mine never did and now it does since ive cleaned the maf ... normal?
Thanks again shep
Forest37
Jun 2, 2009 06:09 AM
akielb
Apr 4, 2007 05:05 PM
Rai
Nov 25, 2005 07:05 PM
TomRitt (Homebrewed)
Performance and Tuning
34
Jan 29, 2005 09:50 PM
patience
12v V6 Discussion
May 19, 2004 06:46 AM
