Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Question: On an 18 x 7.5 wheel, how does different offsets affect the look/performance?
Old Oct 18, 2000 | 01:51 PM
PSS  //  Raj's Avatar
Default Question: On an 18 x 7.5 wheel, how does different offsets affect the look/performance?
I am planning on getting a set of Axis Se7en wheels in 18 x 7.5, and can have any offset I want. My understanding is that a lower offset number means that the wheel will look more tucked in and closer to the hub, whereas a higher offset will make the wheel stick out more (which is what I want). Is this correct? Or am I way off base? In any case, I need to let Axis know ASAP! TIA!
Old Oct 18, 2000 | 02:38 PM
Reggie3's Avatar
Elder Member
Default Smaller offset number the more the wheel is pushed toward the outside of the car
email me for details
Old Oct 18, 2000 | 02:46 PM
Dead's Avatar
Elder Member
You may end up having to have your fenders rolled.
Old Oct 19, 2000 | 03:49 PM
Tracshun's Avatar
New Member
Default Offset Info Link to the Tirerack site
Check out this link regarding offset. Offset is measured from the wheel centerline to the mounting face of a wheels hub, so adding 1/2" ( 7" to 7 1/2" ) wheel width and reducing positive offset by 10 mm ( 3/8"+ ) should yield a net increase of 5/8"+ farther out. ( half the width increase plus the reduced offset - the other half of the width increase goes to the inside )<ul><li><a href="http://www.tirerack.com/wheels/tech/offset.htm">http://www.tirerack.com/wheels/tech/offset.htm</a</li></ul>
mountainsurfer77
Jan 15, 2007 04:33 AM
Lurk'n
Oct 15, 2002 11:45 AM
V8 GECKO
Nov 1, 2001 08:43 AM
Cam
Oct 21, 1999 01:54 PM
