215/55R16 on an A4
Has anyone mounted 215/55R16 on their A4? Sounds like it'd make the overall diameter a smidge over 1cm bigger, which I assume isn't enough to cause concern, but it'd be nice to hear some experience.
Thanks,
-dan
Just FYI, the narrower the snow tire, the better.
Dan<ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
-dan
Lowering the car increases the chances of bottoming out the suspension travel as does adding a wider, taller - or both - tire.
I have the Audi-Eibach sport springs, in the warm months run 225/40x18 on 18x8/35cm offset rims and am running stock wheels with LM22 winter tires now. I have one place on my daily commute that I can make either rub as described above - going into my driveway. So long as I come in a little slower or straighter it isnt a problem. So I guess my answer to you is, you can rub them, but you can also adjust your driving a little and it shouldnt be a problem.
