Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
i just got a set of bbs lm's and i need some advice
Old May 21, 2002 | 07:36 AM
DirtySanchez's Avatar
New Member
Default i just got a set of bbs lm's and i need some advice
i jsut got a set of bbs lm' s. they are 17x8.5 in the front and 17x9.5 in the rear. I was going to run a 225 45 17 in the rear and 215 45 17 in the front. I have been told that the tires would have to be stretched but it should work. I am installing H&R coilovers this week and my car is a 99 quattro. Will this work without too many problems?? Any suggestions??
Old May 21, 2002 | 07:42 AM
MikekiM@PureMS's Avatar
Former Vendor
Why not 225/45 on all four?
Old May 21, 2002 | 08:48 AM
stlthXLR8R's Avatar
Default Re: i just got a set of bbs lm's and i need some advice
The 215/45 17' will be too small for the 8.5 width - handling will suffer. I'm told that correct size for 17 x 8 wheels is 235/45 17. Likewise 225s might be too small for rears...
Old May 21, 2002 | 09:17 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default mixing rim and tire sizes on a quattro is not the greatest idea...
moreover, there is no performance benefit to putting bigger/wider wheels in the back as it is not a RWD car.
Also, the tire sizes you're suggesting are too narrow, given the width of the rims you provided.
I wouldn't put anything narrower than 225/45 on a 8.5" wide rim, and even that is stretching it. I have 225/45 on 8" rims, and they are just flush with the rim edges. Even if it is possible to put on a 215/45 tire on an 8.5" rim, you'll scrape and bend the heck out of the rim lip.
Same goes for 225/45 and 9.5" rims in the rear. I think the max recommended rim width is 8.5". I don't even think that a 17x9.5 rim will fit without rubbing if you'll have an aftermarket sports suspension installed.
All this is assuming you have an A4, which you have not told us ;-)
Audi_in_Van
Nov 26, 2007 10:24 PM
Audiperson
Apr 21, 2002 08:14 PM
slo-twitch
Feb 3, 2002 06:38 PM
Robsond
Jan 22, 2002 12:34 PM
KostaT
Jul 8, 1999 08:13 PM
