Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Gary@Tirerack.com: would an 18x8 et 30mm wheel w/ 225/40/18 tires fit a 96 A4?
Old Mar 9, 2005 | 11:57 PM
pigred's Avatar
Default Gary@Tirerack.com: would an 18x8 et 30mm wheel w/ 225/40/18 tires fit a 96 A4?
Would there be rubbing issues? Or would the 18x9 et 35mm fit my car? If so, what tires would you recommend? The link is the wheel in question. Thanks.<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=7922521810&amp;cat egory=43958">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=7922521810&amp;cat egory=43958</a</li></ul>
Old Mar 10, 2005 | 05:22 AM
Gary@Tirerack.com's Avatar
Former Vendor
Default Re: Gary@Tirerack.com: would an 18x8 et 30mm wheel w/ 225/40/18 tires fit a 96 A4?
The 18X9 is pretty much out of the question. The 18X8 ET30 *might* fit, but 30mm offset is pretty low &lt;outboard&gt; for an 8" so watch for fender clearance. If you roll your fenders and are able to dial more camber in the alignment you should be okay.
S4Dean
Nov 11, 2007 02:53 PM
dolphizzle gray
Feb 2, 2006 06:42 PM
SullyS4
May 10, 2005 06:20 AM
HallmarkAUDI
Oct 7, 2002 05:36 PM
Ray K
Jan 1, 2002 09:34 AM
