Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Swapping wheels
Old Mar 29, 2005 | 06:37 AM
martinman's Avatar
New Member
Default Swapping wheels
Ok, so I have a compressor an impact wrench and a jack. Should I attempt the winter->summer swap? I've always had the local tire place do it, but I'm a bit curious.
The only think I don't have is the torque wrench. How important is this? Can I just impact wrench them on, and then give 'em a good hand tighten?
mm
Old Mar 29, 2005 | 06:41 AM
YosemyTT's Avatar
Default You really should get a torque wrench to do it right.
You can get them pretty cheap if you look around.<ul><li><a href="http://www.whiteboxtools.com/detail.cfm?productID=1013">I have this one and it works just fine.</a></li></ul>
Old Mar 29, 2005 | 11:52 AM
Pat's Avatar
Pat
2nd. Do NOT use an impact wrench.
Old Mar 29, 2005 | 01:39 PM
TEB's Avatar
TEB
No offense, but if you question your qualifications to rotate tires, you probably should get help.
Old Mar 30, 2005 | 10:50 AM
martinman's Avatar
New Member
Offense taken... I'm not asking about rotating tires, read my post again.
Old Mar 30, 2005 | 11:23 AM
btownA4's Avatar
New Member
Default Not quite sure what you mean. If the summer tires are already...
...mounted on wheels, then you're essentially just doing a tire rotation. I highly recommend getting a torque wrench. They're cheap, and can prevent some expensive problems. Over-torquing the lugs can warp your rotors, and unevenly torquing the lugs can cause balance or warping problems.
Old Mar 30, 2005 | 01:09 PM
TEB's Avatar
TEB
Default Rotating from winter to summer, and yes you should get a torque wrench....
And, I would assume that you would rotate the position of your summer tires from where they were when you took them off -- assuming someone took the time to mark their location on the car as they were taking them off.
Regards.
Reggie
RS4 (B7 Platform) Discussion
9
Nov 15, 2007 02:21 AM
Jason in Vancouver
13
Apr 18, 2002 07:29 PM
LinkedUp
Oct 25, 2001 07:53 PM
Nico
Jan 21, 2001 08:51 AM
Craig
Jan 6, 2000 03:37 PM
