Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Wheel Bolt Spray?
Old Oct 22, 2007 | 01:39 PM
Omega's Avatar
Junior Member
Default Wheel Bolt Spray?
Hey guys,
I'm about to change my tires to winter tires and I heard I'm supposed to get some sort of spray for the lug ntus so they come off easier in the spring. What's the spray called?
Thanks
Old Oct 22, 2007 | 02:58 PM
Gary@Tirerack.com's Avatar
Former Vendor
Default Anti Seize, but *don't* do it.
Just google "anti seize and lug torque" and enjoy the reading...
Antiseize makes it nearly impossible to accurately torque the lugs. Its lubricating effects allow the lugs to be tightened further than they should be, which can lead to uneven torque among the studs, overtorquing, and potentially damage to the wheel or studs.
Old Oct 22, 2007 | 04:00 PM
UberVier's Avatar
Default I just spit on mine, lol.
It really does help clean the grime off and lube them going in, and it doesn't last long!
Old Oct 22, 2007 | 08:06 PM
Audi Junkie's Avatar
Community Builder
Default Check that.Ratings are for new clean threads.Anti-sieze overcomes increased starting friction...
that rust and corrosion cause. The two forces of corrosion vs lube cancel each other out to get back to the "clean" thread spec. Real-world is that rusted fasteners cause as much or more inaccuracy than smoothly torqued bolts with lube. Rarely do lab conditions of fresh new bolts with a spcific torque compare to the old rusted bolts on cars in a shop.
imo, this is a typical case of internet knowledge < practical knowledge.
For total accuracy, torque to spec w/anti-sieze and then loosen to the same spec to be sure. That is accurate and will not corrode to a far-out-of-spec situation.<ul><li><a href="http://theoildrop.server101.com/forums/showflat.php?Cat=0&amp;Number=961416&amp;page=0&am p;fpart=all&amp;vc=1">http://theoildrop.server101.com/forums/showflat.php?Cat=0&amp;Number=961416&amp;page=0&am p;fpart=all&amp;vc=1</a</li></ul>
Old Oct 22, 2007 | 08:47 PM
Omega's Avatar
Junior Member
Ok thanks
PetC
Oct 19, 2023 08:19 PM
Bob Petruska
15
Apr 28, 2003 07:57 PM
pshields
Aug 26, 2002 01:13 PM
Jeff Vader - boscoj
Aug 26, 2002 04:11 AM
New A4 fan
Jun 10, 2002 10:56 AM
