Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
tire gurus: tire wear on outer edge - what is it?
Old Oct 29, 2007 | 06:41 AM
telekenetic's Avatar
Default tire gurus: tire wear on outer edge - what is it?
I'm getting considerably uneven wear on outer edge of two front tires on my 2007 Q7. Is this misalignment, wheel balance, inflation pressure, other? Is it a tell tale sign of a single specific issue? If so, what is it?
thanks
Old Oct 29, 2007 | 07:13 AM
Gary@Tirerack.com's Avatar
Former Vendor
Default Re: tire gurus: tire wear on outer edge - what is it?
Normally from hard cornering or camber is set a bit too much in the positive.
Old Oct 30, 2007 | 08:19 AM
jprice@CPS's Avatar
Member
Default Also incorrect toe will wear the outsides of the tires faster (alignment)
Also, crank the steering wheel all the way left and right to check the insides of the tires. If the insides are worn too then it's low pressure that's most likely the culprit.
Old Nov 1, 2007 | 08:11 PM
theonlineguy's Avatar
New Member
im guessing underinflation...check your air
C-Nutts
Dec 10, 2003 02:23 PM
bfm
May 12, 2003 01:34 PM
STXPRESS
Oct 23, 2002 06:24 PM
reza
Apr 25, 2002 09:29 AM
Gary@Ronal
Nov 9, 2000 03:34 PM
