Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Tire Pressure
Old Aug 19, 2008 | 09:38 AM
rmurph's Avatar
New Member
Default Tire Pressure
I have an 03 TT with all wheel drive, 17" tires running factory pressure on tires - 33 psi front and 35 psi rear. Tires are Pirelli. Dealer has aligned car. Problem is the last set were short lived, less than 20,000 mi. Dealer said tires were "cupped". Any suggestions on pressures and alignment.
thanks
Old Aug 19, 2008 | 04:52 PM
Horch it's Avatar
my suggestion is to get new dampers especially if original
Old Aug 20, 2008 | 03:36 AM
ryoung's Avatar
Elder Member
Default How often did you rotate tires?
I prefer 3000 mile intervals.
Old Aug 20, 2008 | 03:50 AM
rmurph's Avatar
New Member
Default Re: How often did you rotate tires?
Rotate every 5000. What pressure do you run front and back?
Old Aug 20, 2008 | 07:40 AM
ryoung's Avatar
Elder Member
Default Well ...
I drive an S8, but <a href="https://forums.audiworld.com/wheel/msgs/71213.phtml">Here's What I Do</a>.
Old Aug 20, 2008 | 08:53 AM
rmurph's Avatar
New Member
Default Re: Well ...
I'll give it a try. Thanks
Old Aug 22, 2008 | 11:49 AM
Scenic Driver's Avatar
Default Those pressures are incorrect >>
The Audi recommended pressures for the TT on 17" wheels is 36 front, 33 rear.
Old Aug 25, 2008 | 01:56 PM
Reggie's Avatar
Club AutoUnion
25 Year Member
Default Good info - cupped was first indication pressures were too low -
I suspected that the fronts should be higher as I run about 1-2 psi higher in my fronts on the A4 and Rs - and suspect they have less weight up front proportionally
 Pouria Savadkouei
 Michael S. Palmer
GBMILTON
Q7 MKII Discussion
Oct 18, 2016 06:01 AM
Inyoury
A6 (C7 Platform) Discussion
21
Sep 15, 2015 08:52 PM
Ming rings in Minn
16
Oct 16, 2007 08:24 PM
bsrpilot
Jul 24, 2007 04:29 PM
UrSoccer_mobileĀ®
Nov 19, 2003 08:02 AM
