Tire pressure keeps getting low
Hi all. I have 20" wheels and Pirelli P zero Summers on my car. I have noticed that the tire pressure on all four tires have gone down a lot lower than I would like. I set the fronts 39 psi and the rear 37 psi. But after a few days of driving around, I noticed that they lose some air pressure and go back down to 33 front and 34 rear. It has happened more recently (the past 1000 miles). I have kept refilling the tires, but keeps happening a few days later. I haven't noticed the pressure to drop below the 33 and 34 psi. Has this happened to anyone?
Thanks
Thanks
I would say your tires leak somewhere. It's quite a coincidence that all four tires leak, but get them checked. Have them check if your wheels are bent. Did you drive over something? Maybe they were just improperly mounted.
I've heard of porous tires, porous rims, bead and valve stem leaks. The only thing that should be changing and is common to all four tires is the ambient temperature.
Make up a soapy solution in a spray bottle, spray the valve stem and beads and look for bubbles.
I decided to order new tires, they straightened my wheels and mounted and balanced my Tire Rack Conti DWS 06 - all is good again.
Point of the story is it's possible to have multiple bent rims which could result in some air loss.
Just need to make another trip to the dealers...
Most bent or out of round rims cannot be detected by eye. They need to be placed on a wheel balancer. Sometimes even then, it won't show up until checked on a Hunter machine.
