Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Looking at 18x8 with a 5x100 pattern fot B5 S4...Fit? No Fit?
Old Nov 18, 2008 | 05:30 AM
TPM2002's Avatar
Member
Default Looking at 18x8 with a 5x100 pattern fot B5 S4...Fit? No Fit?
They are the RS4 style rims off of a TT...
Old Nov 18, 2008 | 08:54 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
no fit 5x112 for A4/S4s
Old Nov 18, 2008 | 09:29 AM
SilverThing's Avatar
Member
^^^^ x2 - no fit
Old Nov 18, 2008 | 10:24 AM
TPM2002's Avatar
Member
Bummer. thanks for the help.
Old Nov 18, 2008 | 10:34 AM
jprice@CPS's Avatar
Member
Default B5 S4 is still 5x112
<a href="https://forums.audiworld.com/wheel/msgs/94860.phtml">https://forums.audiworld.com/wheel/msgs/94860.phtml</a>
Old Nov 18, 2008 | 10:51 AM
TPM2002's Avatar
Member
Yeah im an idiot. forgot i had asked that question before. Fail on my part.
Old Nov 18, 2008 | 12:14 PM
jprice@CPS's Avatar
Member
Default At least you're a good sport! :-D
Best bet is:
-18x8
-ET35
-5x112
-57.1mm center bore (or wheels that accept centering rings that will get you there)
"correct" tire size is 225/40/18, but many run 235/40/18. 235s can rub depending on wheel offset, car ride height, and actual tire width (like shoes, it can vary slightly between manufacturers and models)
Make sure to get the right length and seat bolts for the wheels you end up with.
Old Nov 18, 2008 | 12:34 PM
TPM2002's Avatar
Member
Default Thanks for the specs. That will be very helpful as i search around.
Any rec's on where to get a good original RS4 replica style 18" rim? Like the A6 S-line ones. Hartmann no longer makes the normal ones.
 Pouria Savadkouei
 Michael S. Palmer
phl1230
S4 (B8 Platform) Discussion
Sep 15, 2011 05:00 AM
mizzike2555
9
Apr 7, 2009 04:26 AM
galkokolaf
14
Jan 5, 2007 05:47 PM
I AM 2ks4
22
Nov 15, 2003 04:25 AM
