Non-Flashing Check Engine (MIL) *CAN* be a big deal
Old Dec 18, 1998 | 12:27 PM
chris murphy
Guest
Posts: n/a
Default Non-Flashing Check Engine (MIL) *CAN* be a big deal
I had a non-flashing MIL and drove a mere 60 some miles until I had it corrected at my dealer in Denver. Well I had an injector replaced, and after checking the oil today, it's LOW (I need to add a quart), and the big problem is that it reeks of fuel and definitely needs to be changed. So this necessitates yet another trip to the dealer.<p>So it's not always the case that the non-flashing MIL is not a big deal. Sometimes it is, and sometimes it isn't.<p><br>Chris Murphy<br>1998 A4 2.8QM Pearl<p>
Old Dec 18, 1998 | 03:27 PM
Dale B
Guest
Posts: n/a
Default Even a non-lit MIL can be a big deal, for that matter
For some problems, the light doesn't even come on. For example, a misfire. If some of these types of problems happen enough times, the light comes on. So, it is possible for the ECU to detect a big problem, especially the beginnings of one, long before it tells you about it. (The reason the light doesn't come on, necessarily, is that the problem isn't necessarily severe, and the system wants to verify it is "real" before sounding the alarm). And, of course, the ECU doesn't even keep track of lots of things that can be problems. It can't watch carbon buildup on the valves, for example, and it won't tell you if your engine mounts are about to rust through. Unfortunately, it DOES track lots of things that most of us wish it didn't track, like the fuel tank pressure, which can cause a light if the gas cap isn't screwed on right.
Old Dec 18, 1998 | 07:06 PM
chris murphy
Guest
Posts: n/a
Default Re: fuel cap (and a TRIVIA Q&A)
<br>Actually I don't mind the fuel cap. I've been used to the environmentally friendly (supposedly) fuel cap that clicks for a while; and the proper way to put it back on it until it clicks. So if I get a MIL because of that, then it's because I forgot my fuel cap.<p>How long does it take for the MIL to come on if you don't have the cap on?<p>Trivia: MIL stands for what?<p><p>Malfunction Indicator Lamp (not light) - those Germans!<p><br>Chris Murphy<br>1998 A42.8QM Pearl
Evil A4 666
Dec 22, 2006 07:33 AM
DWP
Aug 5, 2000 02:29 PM
richard b
Jul 19, 1999 08:40 AM
js
May 11, 1999 08:44 AM
oggie
Jan 15, 1999 08:54 AM
