Quattro + ESP question
Old Jan 20, 2001 | 06:48 AM
Flask's Avatar
Default Quattro + ESP question
Setting: Tightly turning ramp onto an interstate highway. Speed limit for ramp is either 35 or 40.
I entered the ramp at 45 and accelerated to about 60-65 when I hit the main road. While on the ramp, the tires were screeching loudly and I could feel significant understeer. It was a really tight ramp and there was lots of force pulling the car sideways. I was surprised at how much noise the tires were making.
Anyway, I was thinking that ESP would have worked a little harder to handle the understeer. Any thoughts?
Old Jan 20, 2001 | 07:46 AM
unA4dable's Avatar
New Member
Default Re: Quattro + ESP question
A couple of thoughts:
1) ESP won't do anything unless there's a more, umm, acute problem. Unless you actually lose the front end, ESP won't correct. It really functions to get you back on track once you lose one end of the car or the other, when the car's instantaneous yaw rate doesn't match up with what would be expected by the system given the current speed and steering angle input.
2) If you were severly understeering and this wasn't a major uphill ramp (which would cause a lot of rearward weight transfer), I'd check to make sure tire pressure is really where you want it to be at all four corners.
-dan
Old Jan 20, 2001 | 07:55 AM
Flask's Avatar
Default The Summer 2000 Quattro Quarterly mag had an explanation of ESP (more)
and it made me think that ESP was functional in cases like I described.
My pressures are currently set at 36 front and rear. I think handling was better with them set at 32 front and rear.
Old Jan 20, 2001 | 10:58 AM
[ej257]'s Avatar
Member
Default quattro and esp ann the best of tires cant deny the laws of physics
thats seems more like the tires were screeching, not a loss of wheelspin.
Old Jan 20, 2001 | 12:19 PM
Flask's Avatar
The wheels were certainly not spinning. It was sideways force that was making them screech
KenK in TX
Audi A3 / S3 / RS 3
Dec 15, 2007 04:18 PM
s.cars
May 2, 2007 12:14 PM
slimmn
Oct 1, 2003 07:08 PM
Sourdough Josh
11
May 1, 2003 05:51 PM
PKpro
9
Jul 16, 2001 01:13 PM
