Two basic questions on the 30v 2.8 engine...
2) Is the oil filter readily accessible from the underside, and where is it? I want to install a magnetic strap to help reduce the break-in shavings floating around. I took a quick peek and didnt see it since I cant fit under the car.
The filter is accessible, but you need to remove the cover underneath the engine. To do this you will need to get car up on ramps or jack stands. I don't think you can reach from top.
How steady is the warm idle on your A4? Mine has a tendency to 'wander' as much as 100 rpm.
The oil filter is easy to reach once you have removed the plastic belly pan under the engine. Undo about 6 fasteners, IIRC, holding the pan to the chassis and remove the pan. The filter is on the front left hand (driver's side in Nth America) of the engine. It helps to have the front of the car raised at least a few inches.
The oil filter sounds like a real pain, but I think its worth the trouble to throw the strap onto it.
Thanks for the info!
