Compression? Valve job
Old Jan 21, 2001 | 07:46 PM
A4legend's Avatar
New Member
Default Compression? Valve job
My A4 needs a valve job, I think. One cylinder is running at 80 lbs the others normal. What would cause this for a motor with less than 80K mi, if this possible? Any info greatly appreciated. If I have to do it I will. The car is worth it to me.
Old Jan 21, 2001 | 09:24 PM
Clark@turbo5.com's Avatar
Junior Member
Default You need to do a leak down.
A leak down is the only way to really tell whats going on. I suspect that you have a broken ring for a bent valve. A leak down will tell exactly where the compression leak is. 1.8t's are tight motors. Mine is 185 psi on all four with about 1% leak down after 32,000 HARD miles.
Clark
CartoonDog
Oct 31, 2008 09:28 AM
mannywdc
Audi Original "S" Cars
9
Aug 1, 2006 02:42 PM
nadrealista
May 12, 2005 06:50 AM
2.7tDallas REFORMED
60
May 14, 2004 04:16 AM
nkk@auto
Feb 19, 2003 11:15 AM
