Test Forum B5 FAQ
genstat.m
Old Jun 28, 2002 | 12:59 PM
SuspendedLikeaMoFo.'s Avatar
Elder Member
Default genstat.m
% GENSTAT.M calculates the projectile range
% using a set of launch angles derived from
% random samples from a normal distribution
% Rid the screen of clutter
clc
% Display a banner
disp ( '**********************************' )
disp ( '* PROGRAM GENSTAT.M *' )
% Get the number of samples from the user
num_samples = input ( '\nEnter the number of samples: ' );
% Get the desired mean and standard deviation
desired_mean = input ( '\nEnter the mean: ' );
desired_std = input ( '\nEnter the standard deviation: ');
% Calculate the sample vector
theta0 = desired_std*randn(1, num_samples) + desired_mean;
fprintf( '\nLaunch angle samples\n' );
fprintf( ' %10.5f\n', theta0' );
% Calculate the range
fprintf ('\n\n')
V0 = input ('Enter desired launch velocity (m/s): ');
x0 = input ('Enter desired initial x-position (m): ');
z0 = input ('Enter desired initial z-position (m): ');
fprintf ( '\nCalculating range vector...\n' )
R = range0( V0, theta0, x0, z0 );
% Mean and standard deviation of R
[mean_of_R, sigma_of_R] = stats (R);
fprintf ('\nThe mean R is %10.5f (m)', mean_of_R )
fprintf ('\nThe standard deviation of R is %10.5f (m)\n\n', sigma_of_R)
Elder Member
Default genx.m
function x = genx (np, ns, mean, sigma)
% GENX.M generates a vector x of data values
% between mean-n*sigma and mean+n*sigm
% np = number of points to generate
% ns = 2*ns is the width of x in sigmas
% mean = mean of x
% sigma = standard deviation of x
x = [ mean-ns*sigma: 2*sigma/np: mean+ns*sigma ];
Old Jun 28, 2002 | 01:00 PM
Elder Member
Default hgramf.m
function hgramf (data_vector)
% Histogram-generating function
% bin_centers = vector containing centers of bins
% data_vector = vector of pressure measurments
% frequency = vector giving fractional number
% of measurements in each bin.
% m = number of bins in histogram
% n = number of measurements in each bin
% num_meas = number of measurements
% Clear the clutter
clc
% Set up m, equally-spaced histogram bins
m = input ( '\n Enter the number of equally-spaced bins: ' );
% Number in each (n) bin and bin centers
[n, bin_centers] = hist (data_vector, m);
% Set up a subplot array with
% 1 row, 2 columns, and the histogram
% in the 1st column
subplot (1, 2, 1)
% Histogram
hist (data_vector, m), xlabel ('pressure (psi)'),...
ylabel ('quantity in bin'),...
title('Pressure Measurement Histogram');
% Put the bar chart in row 1, column 2
subplot (1, 2, 2)
% Frequency distribution
num_meas = length (data_vector); % A speed-up: num_meas used twice
frequency = n/num_meas;
bar (bin_centers, frequency), xlabel ('pressure (psi)'),...
ylabel ('frequency'),...
title('Pressure Measurement Frequency Distribution');
% Display bin data
fprintf ('\n There were %3.0f measurements.\n\n', num_meas);
disp (' bin Center (psi) count frequency')
A = [ bin_centers; n; frequency ]; % You have to put them in a matrix
fprintf (' %4.3f %2.0f %6.4f\n', A)
Elder Member
Default histdemo.m
% HISTDEMO.M is a Histogram-generating program
% p_data = vector of pressure measurments
% Load the data
load p_data.txt
% Clear the clutter
clc
[n, bin_centers] = hist (p_data, m);
% in the 1st column
subplot (1, 2, 1)
% Histogram
hist (p_data, m), xlabel ('pressure (psi)'),...
subplot (1, 2, 2)
num_meas = length (p_data); % A speed-up: num_meas used twice
% Display bin data
Old Jun 28, 2002 | 01:01 PM
Elder Member
Default histdemo2.m
% Load the data
load p_data.txt
% Clear the clutter
clc
% in the 1st column
%subplot (1, 2, 1)
% Histogram
%hist (p_data, m), xlabel ('pressure (psi)'),...
% ylabel ('quantity in bin'),...
% title('Pressure Measurement Histogram');
%subplot (1, 2, 2)
measurements = length (p_data); % A speed-up: num_meas used twice
frequency = n/measurements;
% Display bin data
fprintf ('\n There were %3.0f measurements.\n\n', measurements);
Elder Member
Default normpdf.m
function p = normpdf ( x, mean, sigma )
% NORMPDF.M calculates and plots a
% normal probability density function.
% mean = mean of the data vector, x
% sigma = standard deviation of data vector, x
% x = data vector over which to find p(x)
% p(x) = probability density function
normalizer = 1/(sigma*sqrt(2*pi));
p = normalizer*exp( -0.5*( (x - mean)/sigma ).^2 );
Elder Member
Default p_data38.txt
4.95
4.87
5.1
4.99
5.06
5.09
4.95
5.01
4.98
4.99
5.0
5.05
5.0
5.02
5.01
5.06
4.99
5.01
4.98
4.97
4.92
4.93
5.00
4.98
4.92
4.91
5.06
5.01
4.98
4.97
5.02
4.92
4.94
4.98
4.99
4.92
5.04
5.00
Old Jun 28, 2002 | 01:02 PM
Elder Member
Default range0.m
function R = range0( V0, theta0, x0, z0 )
% RANG0.M calculates the range given launch
% conditions and no drag.
% Variable definitions
% theta0 = launch angle (degrees)
% V0 = launch velocity (m/s)
% x0 = launch x-coordinate (m)
% z0 = launch z-coordinate (m)
% Specify constants
g = 9.807; % m/s^2
% Calculate Vx0, Vz0 (m/s)
theta0r = theta0*pi./180;
Vx0 = V0*cos( theta0r );
Vz0 = V0*sin( theta0r );
% Find the time of flight (s)
for j = 1:length(theta0)
c = [ -.5*g Vz0(j) z0 ];
the_roots_of_c = roots(c);
if the_roots_of_c(1) > 0
time_of_flight(j) = the_roots_of_c(1);
else
time_of_flight(j) = the_roots_of_c(2);
end
end
R = Vx0.*time_of_flight;
 Pouria Savadkouei
 Michael S. Palmer
Elder Member
Default readdata.m
[velocity] = textread('p_data.txt','%f',...
'headerlines',0)
Elder Member
Default stats.m
function [ mean, std_dev ] = stats ( x )
% STATS.M computes the mean and standard deviation
% of a vector of data.
% lengthx = the number of entries in x
% mean = the average of x
% std_dev = the standard deviation of x
% x = a vector containing sample
% of x
% Find the length of sample x
lengthx = length(x);
% Find the mean of the lengthx samples
mean = sum(x)/lengthx;
% Find the standard deviation of the samples
std_dev = sum( ( mean - x ).^2 )/(lengthx - 1 );
