Testing
Work previously completed:
<img src="http://www.audipages.com/house/sm_DSC07761.JPG">
<img src="http://www.audipages.com/house/sm_DSC07786.JPG">
<img src="http://www.audipages.com/house/sm_DSC07787.JPG">
There will be four shelves, two per outboard "cubbie", and six drawers, three per section inboard of the "cubbie", outboard of the radiator section...made the drawers previously, they will have solid maple fronts.
<img src="http://www.audipages.com/house/sm_DSC07767.JPG">
So here is where I'm at.....finished the fronts, finished the cubbies except for the shelves, sanded and put on 4 coats of poly on the inside of the cubbies, and two coats everywhere else on the inside to seal the thing....
It's covering two outlets on the wall, so that I put outlets on the furniture that I will hardwire in.....it also have four lights that dim at three levels for above each of the shelf sections, you can see the light switch under the front of it......just so you know, this thing is backwards and upside down now.....
<img src="http://www.audipages.com/house/sm_DSC00129.JPG">
The cubbie sides and back are in....the drawer section goes in the two middle sections.....
<img src="http://www.audipages.com/house/sm_DSC00131.JPG">
<img src="http://www.audipages.com/house/sm_DSC00132.JPG">
<img src="http://www.audipages.com/house/sm_DSC00133.JPG">
I'm wiring it up.....got lights that have a three setting dimmer power supply, the switch is just a static button.....Hampton Bay from Home Depot (I hate that store). The switch is the white thing, it will be just under the lip when flipped over.
<img src="http://www.audipages.com/house/sm_DSC00136.JPG">
<img src="http://www.audipages.com/house/sm_DSC00135.JPG">
<img src="http://www.audipages.com/house/sm_DSC00127.JPG">
Here is the sister unit already installed at the other window......
<img src="http://www.audipages.com/house/sm_DSC07228.JPG">
It's almost done....just need to add the drawer fronts now, finish them and put the hardware on.
Total number of pieces of wood: 88
Probably about 100 biscuits used to join everything.
About 60 screws, 2 quarts of poly, and a few nails.
Power supply for lighting, has three voltage levels...
<img src="http://www.audipages.com/house/sm_DSC00150.JPG">
Just plugging it into the wall for power.....
<img src="http://www.audipages.com/house/sm_DSC00155.JPG">
It's upside down, this is the bottom shelf....shimmed to perfection....
<img src="http://www.audipages.com/house/sm_DSC00165.JPG">
Lighting installed....
<img src="http://www.audipages.com/house/sm_DSC00168.JPG">
<img src="http://www.audipages.com/house/sm_DSC00174.JPG">
Flipped right side up for the first time in 9 months.....
<img src="http://www.audipages.com/house/sm_DSC00179.JPG">
Audi A4 for scale.....
<img src="http://www.audipages.com/house/sm_DSC00181.JPG">
<img src="http://www.audipages.com/house/sm_DSC00186.JPG">
<img src="http://www.audipages.com/house/sm_DSC00189.JPG">
The drawers are installed, need to put the maple fronts on them now.....
<img src="http://www.audipages.com/house/sm_DSC00197.JPG">
<img src="http://www.audipages.com/house/sm_DSC00198.JPG">
Top is only two pieces....
<img src="http://www.audipages.com/house/sm_DSC00204.JPG">
Each side has outlets since I covered two of them up....
<img src="http://www.audipages.com/house/sm_DSC00206.JPG">
And behind the drawers it plugs into the wall....
<img src="http://www.audipages.com/house/sm_DSC00207.JPG">
And sister unit built last year on other window....
It came out very, very nice. With the drawer fronts on, the little nick nacks in it, it is stunning......
Just have two more things to do in the living room.....putting six 32" x 24" or so dark wood panels above the couch for a poor man's art project, don't have big money for a painting right now......
And a ceiling fan in the open circuit in the ceiling.....got to find a very cool one without a light.
Even finished the last two pieces of baseboard last night.
<img src="http://www.audipages.com/house/sm_DSC00273.JPG">
<img src="http://www.audipages.com/house/sm_DSC00282.JPG">
<img src="http://www.audipages.com/house/sm_DSC00295.JPG">
<img src="http://www.audipages.com/house/sm_DSC00298.JPG">
<img src="http://www.audipages.com/house/sm_DSC00301.JPG">
<img src="http://www.audipages.com/house/sm_DSC00303.JPG">
<img src="http://www.audipages.com/house/sm_DSC00309.JPG">
<img src="http://www.audipages.com/house/sm_DSC00305.JPG">
BTW, here was the house before we bought it.....note radiator and window.......
<img src="http://www.audipages.com/house/sm_DSC02154.JPG">
And one during construction.....
<img src="http://www.audipages.com/house/sm_DSC06378.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6293.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6295.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6296.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6307.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6309.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6298.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6303.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6305.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6313.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6315.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6318.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6323.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6324.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6326.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6650.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6651.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6654.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6661.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6662.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6663.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6664.JPG">
This is the front of the building at about 1:00 P.M. today.
<img src="http://www.audipages.com/house/sm_DSC_6669.JPG">
Worked 9-12 hours a day....had four roofers working 12 hours a day for three days, and then three guys finished up the fourth day.
I hired a helper for me for the whole week, and he brought somebody else in for 1.5 days....oh so glad we did that.
So here are the pictures (if they don't load, hit refresh):
<img src="http://www.audipages.com/house/sm_DSC_6978.JPG">
<img src="http://www.audipages.com/house/sm_DSC_6980.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7029.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7032.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7038.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7039.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7042.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7043.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7044.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7047.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7053.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7055.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7063.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7066.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7068.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7072.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7081.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7094.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7095.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7100.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7105.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7110.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7116.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7118.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7121.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7123.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7127.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7137.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7138.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7139.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7142.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7144.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7146.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7149.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7153.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7156.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7164.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7167.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7171.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7174.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7180.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7183.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7185.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7187.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7190.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7196.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7199.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7220.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7224.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7228.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7232.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7238.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7240.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7243.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7245.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7248.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7249.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7250.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7261.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7269.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7277.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7278.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7289.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7291.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7296.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7297.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7299.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7303.JPG">
<img src="http://www.audipages.com/house/sm_DSC_7304.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8102.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8105.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8106.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8346.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8353.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8373.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8375.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8376.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8377.JPG">
Built the front out 1 1/2" by facing it with 2x4's and 2x2's so it will be deep enough......took 2x4's out of the inside width to increase it by 3", then 1/2" plywood went in to reduce it to 2". Added 2x's on the outside to increase the outside width by 3" so it maintains proportion. It will be perfect, approximately 1" all the way around the TV after the finish bamboo goes in. It looks over the top cool, you don't get how big it is and how nice it looks from the pictures. It's 48" wide.
<img src="http://www.audipages.com/house/sm_DSC_8391.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8389.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8392.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8396.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8397.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8400.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8402.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8403.JPG">
Finished the headboard/bed area the other day....it's about 10 1/2' across.
<img src="http://www.audipages.com/house/sm_DSC_8406.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8408.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8416.JPG">
Then start with a nice Ribeye....
<img src="http://www.audipages.com/house/sm_DSC_8410.JPG">
Trim the fat....
<img src="http://www.audipages.com/house/sm_DSC_8412.JPG">
Slice it thin and use a rolling pin to flatten it even more.....
<img src="http://www.audipages.com/house/sm_DSC_8414.JPG">
One steak, thank you.
<img src="http://www.audipages.com/house/sm_DSC_8420.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8432.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8436.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8438.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8441.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8446.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8447.JPG">
Provolne cheese ontop of half the meat.....
<img src="http://www.audipages.com/house/sm_DSC_8449.JPG">
Then the other half of the meat and more provolne.....top with onions and turn heat off.
<img src="http://www.audipages.com/house/sm_DSC_8451.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8453.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8460.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8461.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8469.JPG">
Make the bun "skinny".....grill it and put some mayo on it.....
<img src="http://www.audipages.com/house/sm_DSC_8421.JPG">
Got to have some fries with something like this....
<img src="http://www.audipages.com/house/sm_DSC_8457.JPG">
And the master piece!
<img src="http://www.audipages.com/house/sm_DSC_8471.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8473.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8477.JPG">
Start Friday afternoon, then table saw breaks and I need a new belt pulley. Procure it Saturday, fight with it to get it on....then Saturday afternoon I finish the wood on the walls, then Sunday I install and trim the storage cabinets.
They will have custom made curtains in front of them.
From last week:
<img src="http://www.audipages.com/house/sm_DSC_8596.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8622.JPG">
Then this weekend.
<img src="http://www.audipages.com/house/sm_DSC_8634.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8636.JPG">
Shim blocks to secure the cabinets to.
<img src="http://www.audipages.com/house/sm_DSC_8637.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8638.JPG">
Trim backers to nail the bamboo trim up once the cabinet is installed.
<img src="http://www.audipages.com/house/sm_DSC_8641.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8640.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8651.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8658.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8659.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8649.JPG">
<img src="http://www.audipages.com/house/sm_DSC_8644.JPG">
