testing, testing
The auto spray controller takes inputs from the fuel injector cycles and automatically sprays water on the intercooler to keep the intake air down or cooler. Since it knows when you request power from the engine because it is monitoring the injectors it sprays ahead of the hot air going through the intercooler keeping it cool thus no heat soaking. The temperature gage read the hot air before it passes through the intercooler and after it as gone through to see the temperature drop. I'm hoping this system will keep my horse power up under hot and humid days and some say it will actually increase power under some conditions.
<img src="http://pictureposter.audiworld.com/46874/blackbox03.jpg">
<b> C.P.P.'s custom made adjustable upper control arms. </b>
<img src="http://pictureposter.audiworld.com/46874/cppupperarms02.jpg">
<b> Audi's upper strut stress bar. </b>
<img src="http://pictureposter.audiworld.com/46874/upperstrut01.jpg">
<b> upper strut stress bar close up picture of brackets to br welded on. </b>
<img src="http://pictureposter.audiworld.com/46874/upperstrut02.jpg">
<b> Audi's OEM front suspension lower control arms. </b>
<img src="http://pictureposter.audiworld.com/46874/oemlowerarms02.jpg">
<b> C.P.P.'s custom modified lower control arms </b>
with concentric..... Spherical bearings. (this is a first)
<img src="http://pictureposter.audiworld.com/46874/cpplowerarms02.jpg">
<b> Close up of brass inset. </b>
<img src="http://pictureposter.audiworld.com/46874/cpplowerarms03.jpg">
<b> BBS wheel studs. </b>
Makes wheel install faster and easier and the other benefit is safety, they use studs in racing.
<img src="http://pictureposter.audiworld.com/46874/bbsstuds02.jpg">
<b> BBS studs installed on hub. </b>
<img src="http://pictureposter.audiworld.com/46874/bbsstuds03.jpg">
<b> BBS wheel studs with 15 OEM mag wheel. </b>
<img src="http://pictureposter.audiworld.com/46874/bbsstuds04.jpg">
<b> Stainless steel brake lines. </b>
These lines work with the regular brake calipers. I have another Front set to work with the Porsche calipers.
<img src="http://pictureposter.audiworld.com/46874/goodridgelines.jpg">
