'01 Electrical Problem - HELP PLEASE
I have an '01 225 Coupe. Currently, the car will not start and I just installed a new battery a few months ago. When I turn the key I do not hear the common clicking sound associated with a dead battery AND this weekend while driving both the RPM and MPH guage dropped to zero and the radio cut out for a few seconds before coming back to life.
Please Help!!! The dealer thinks I may need a new cluster but what would cause the car not to start? I can't even turn on the radio as if the power is completely gone and I had to use the key to enter the car instad of the remote.
Thanks!
Neil
All of the symptoms you describe sound like a battery to me...IMO
FWIW, when I've tried to start my immobilzer-equipped 2001 with a non-coded key, the engine starts up normally, but then dies after a second or two. My guess is that you've got a battery or other electrical problem (also check those main fuses that sit atop the battery box... make sure the 10mm bolts on each end are snugged down).
