2181 code
Old Nov 30, 2011 | 02:22 AM
skylordd's Avatar
Default 2181 code
I just had a check engine light come on and checked the code and it said 2181 cooling system performance. what does that mean ? Level is good, temp is within range, ??? anyone have any ideas, It came on after I did a short 95 MPH burst down the interstate then let it coast up the off ramp.
Old Nov 30, 2011 | 06:29 AM
AudiMick's Avatar
It's usually because the car is not warming up or cooling down fast enough.
Your TT should warm up so the gauge is at 12 o'clock within about 5 minutes or so. The gauge should not move around once it gets there regardless of how fast you went.
Sluggish thermostat, bad CTS or plastic water pump impeller.
Old Nov 30, 2011 | 12:47 PM
skylordd's Avatar
Water pump was replaced with the timing belt change and it was a metal impeller. so I guess I'll change out the thermostat. Car seems to heat up ok and heater works fine . I do have a faint smell of antifreeze in the cabin but show no signs of losing fluid anywhere. marked the overflow bottle and level hasnt changed.
Old Dec 1, 2011 | 06:59 AM
AudiMick's Avatar
If you change thermostat also replace the plastic coolant flange and o-ring. They become brittle over time and don't seem to survive being taken on and off.
Cheap part.
Old Dec 1, 2011 | 04:39 PM
skylordd's Avatar
Yes , I have all those parts , THANKS. What is the CTS ?
Old Dec 1, 2011 | 04:40 PM
skylordd's Avatar
Where is the water temp sensor located, cant seem to find it ?
Old Dec 2, 2011 | 05:22 AM
AudiMick's Avatar
Coolant Temp Sensor.On the right of the motor ( standing in front of car) , in a plastic pipe coming out of the top of the block.
Old Dec 4, 2011 | 05:44 AM
skylordd's Avatar
Thanks Mick, I replaced the CTS this morning , which had quit last week about the same time as this light came on. could that be the reason the light came on ? I will replace the thermostat and housing as well as the coolant flange in the spring when I change out the timing belt and associated parts. How do I clear the Check engine light now that the gauge is working (if this was the cause) ?
Old Dec 4, 2011 | 06:54 AM
AudiMick's Avatar
Use a VAG.com or OBDII scanner or see if it clears on it's own. If it's fixed it should go away on it's own it might take a few days as I think it needs a few warm up cycles..
Metronet
10
Nov 20, 2022 10:00 AM
mexiaudi
Dec 1, 2013 01:31 PM
nomogates
Oct 9, 2005 10:51 AM
hAUDIni
Nov 13, 2004 03:55 PM
XcellR8edAudi
Sep 4, 2004 10:06 AM
