5th digit engine code????
Old Apr 24, 2020 | 07:43 PM
Green_zj's Avatar
Default 5th digit engine code????
I was curious as to what the difference is between the AWP(C) and the AWP(X) where the C or the X is the 5th digit in the vin?
Old Apr 29, 2020 | 12:53 PM
Geomeo's Avatar
Where are you actually seeing the x or c? The only C I can ever think of seeing was on the block itself, there’s an 8 or 9 digit code before it. Starts with 06A or 058 etc. The AWP is stamped on a slant near the trans to the right of the engine oil filter. It’s also on the cylinder head sometimes. if you’re looking for a replacement used engine then a Jetta, beetle, gti 1.8T should work. Look for the one that starts with 06A on the side of the block. As I don’t think the tts had 058 blocks. Although I’ve heard the end where the flywheel sits on may differ between the manual and auto. Never seen it myself. But manuals are becoming rare in the us. So I don’t know. Once fitted you should find a reputable tuner, because well short answer, better smoother quicker running engine....Other answer google wiki Audi s4 tuning.
p8ntball_89
12v V6 Discussion
Sep 2, 2022 05:36 AM
Audi2.8L
Mar 8, 2010 07:58 PM
Audi2.8L
Mar 8, 2010 07:56 PM
chris20vT
Mar 9, 2003 08:45 PM
süpercüp
Aug 25, 2002 12:19 AM
