air bag sensor
Old Apr 30, 2025 | 02:22 PM
Ric0shea's Avatar
Default air bag sensor
I installed a new (used) air bag sensor in my 2001 TT. My previous one had the dreaded internal memory fault. The new one gets 3 codes...
01044-Control module incorrectly coded 35-00
00591-seat belt switch; driver (E24) 35-00
00592-seat belt switch; passenger (E25) 35-00
I cleared the codes successfully with VCDS, but they came back right away.
Is there a way to reprogram the control module code?
Old Apr 30, 2025 | 02:33 PM
03_AR_CO's Avatar
Does the coding in you VCDS look like this for your airbag control module?:
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601 TA
Component: Airbag Front+Seite 1008
Coding: 10103
Shop #: WSC 07315
VCID: 0C1C406E3C169BF6AF-5120
No fault code found.
Also used airbag modules cannot be considered reliable
Old Apr 30, 2025 | 02:42 PM
Ric0shea's Avatar
Mine is...
Address 15: Airbags. Labels: 8N8-909-601. LBL
Controller: 8N8 909 601
Component: Airbag Front+Seite 2008
Coding: 10102
Shop # WSC 01236
VCID: F78119C6D5
I can see there are 2 #s different. I just dug thru my old paperwork and found a report with the old sensor...it has the same #s as you listed.
I realize that used is not the way to go, but they haven't made these new in a long time.
So my question stands...can I recode this?
Old Apr 30, 2025 | 05:28 PM
03_AR_CO's Avatar
certainly no harm in trying, you can always code it back to the way you found it, not sure what the difference between your new one and the ones ending in TA, that may make a difference. Any way to confirm what car it came out of, mine is a 2001
Old May 1, 2025 | 07:26 AM
Ric0shea's Avatar
An update...I changed the coding from 10102 to 10103. I then cleared all 3 codes and this time they didn't come back.
According to VCDS, the difference between the 2 and 3 is the Seat Belt Switches.
Old May 1, 2025 | 04:53 PM
03_AR_CO's Avatar
Glad it worked for you and you have a good controller
Old May 1, 2025 | 05:13 PM
Ric0shea's Avatar
Thanks for the help.
m1964
Q5/SQ5 MKI (8R) Discussion
Mar 23, 2021 08:59 AM
Power-Gomez
May 16, 2018 01:37 AM
Projekt 8E
Sep 28, 2015 05:49 PM
corne
Audi 100 / A6 (C4 Platform)
May 26, 2007 09:13 PM
5221
Aug 24, 2005 06:05 PM
