airbag light, again
Old Mar 7, 2009 | 07:56 AM
dnelson's Avatar
New Member
Default airbag light, again
I've read prior threads. My recently acquired 01 roadster has the airbag light on. Other than not being able to count on a properly functioning airbag, and the annoyance of the light, are there any foreseeable negative consequences of ignoring it?
Old Mar 7, 2009 | 08:44 AM
XCLR8TT's Avatar
Senior Member
dying?>
Old Mar 7, 2009 | 08:47 AM
roadyTT's Avatar
Dying after 3-6 weeks in the ICU
Old Mar 7, 2009 | 09:15 AM
debashis's Avatar
lol! dying if lucky, permanent injuries if not!
Old Mar 7, 2009 | 09:38 AM
dnelson's Avatar
New Member
Default Re: dying?>
lol! I appreciate that. But for the car, I'll take these answers as a NO?
Old Mar 7, 2009 | 09:44 AM
debashis's Avatar
by 'again', do you mean you have already changed the airbag control module?
Old Mar 7, 2009 | 09:54 AM
DumpTTruck's Avatar
You guys are funny. My first couple of cars had no seatbelts. At least he has those.
Old Mar 7, 2009 | 10:02 AM
XCLR8TT's Avatar
Senior Member
Check the codes with Vag Com. It may also be a case of the connector under the seat being loose.
Old Mar 7, 2009 | 02:31 PM
CubFan63's Avatar
Member
Default I've seen so many posts about this lately, and mine is on as well...
Virtually everyone that's posted has talked about the cold weather when the light came on. I know I put my seat heaters on when it's cold and I would assume many others did also. I'm wondering if the way the airbag and seat heaters are wired, or share something in common under the seat, that when the seat heaters are used it is causing this airbag light issue. I've tried looking at the wiring diagram, but I may as well be trying to read Chinese.
Has anyone looked at this since it does seem to happen predominately in the winter/colder months? Would it surprise anyone if Audi went with a less than sufficient part to handle those loads together?
Just curious.
Old Mar 7, 2009 | 03:03 PM
XCLR8TT's Avatar
Senior Member
The side airbag plugs in under the seat, as well as the seat heater. Check there first.
stampede253
Oct 17, 2010 08:07 PM
98Quattro
Aug 26, 2010 08:23 AM
Link20vt
Mar 26, 2003 08:03 AM
Audi_2000_1.8t
Jul 10, 2000 08:40 AM
