Alien door opens
Old Jan 30, 2005 | 04:38 PM
XCLR8TT's Avatar
Senior Member
Default Alien door opens
My left alien opens about 1/2" when I shut the car off. Is there something I can adjust so it stays closed down?
Old Jan 30, 2005 | 05:01 PM
BTTI's Avatar
Senior Member
Default Again, I'd have to say explosives...
but that's more like getting rid of it altogether
Old Jan 30, 2005 | 05:14 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default They wanna be free!!
seriously, they're activated by pressure from the Alien pump...That should not be happening unless your pump is pressurizing the system somehow..
Old Jan 30, 2005 | 08:34 PM
cedricl's Avatar
Default Is there any way to deactivate them?
I'd like to just not have them come on because all they do is use water that can be better used on my windshield. S.F Bay Area cars really don't need to have headlight washers. No mud or salt on the roads.
Old Jan 31, 2005 | 04:54 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default You can undo the main disconnect, and plug it. Then no pressure will be able to get to the pumps...
<center><img src="http://images7.fotki.com/v150/photos/4/435091/1799877/33Aliensdisconnect2-vi.jpg"></center><p>However, if your is somehow broken, it may still stick out. I could image that they are held close by a spring, and the fluid pressure overcomes that spring to let it extend and spray. If the sping were broken, it would remain extended. That's not at all to say that is how it is designed, I am just guessing.
Anyways, in the photo, you can see where the aliens get their "nourishment". You can disconnect it there, or cut the line and plug it anywhere along the path. The line runs under the drivers wheel well, under the splash shield, and is about a 3/8" diameter line. If/when you do disconnect it, have a bucket handy to catch all the fluid, as the entire washer reservoir contents will flow out.
Old Jan 31, 2005 | 06:31 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Or unplug this harness...>...
Don't know if there's a separate fuse...Check your manual as that would be easier. This plug is at the bottom rear of the drivers wheel well, under the fender liner. The bottom pump is the one for the aliens.
<img src="http://images1.fotki.com/v5/photos/7/7305/111929/DSCF0008-vi.jpg">
Old Jan 31, 2005 | 06:37 AM
Tech Guru
That's probably better. If you plug it, you are dead-heading the pump...
Old Jan 31, 2005 | 09:43 AM
cedricl's Avatar
Thanks to the responses
 Michael S. Palmer
Regenmeister
Nov 23, 2005 05:53 AM
Flyboy
Jun 20, 2003 04:43 AM
Rockin Ronnie
14
Jun 17, 2003 05:32 PM
Vince Krey
14
Mar 7, 2002 11:50 AM
KAOS, AZ (Papa Smurf)
23
Oct 16, 2001 04:37 PM
