Alignment Issues: Pic Request....
Old Jan 15, 2009 | 06:14 AM
EuroStyle's Avatar
Default Alignment Issues: Pic Request....
I took the TT in for an alignment and the rear toe is really off. This is the place I have always taken my older VW's and Audi's....but on the TT he said he wasn't sure how or if they can adjust the rear toe. After reading through the search, I see you can via the elongated holes where the trailing arms bolt on. I did see some old pics of this in the search, but they don't work. Does anyone have it saved?
Right now the right rear is .35 and the left is .65, which explains why the car is so twitchy in the rear on snow/ice. Somehow I don't think there is enough adjustment in the car to get back down to 0...can the holes be elongated easily? I had an old Volvo 242 Turbo and this was the only way to get the alignment in spec.....
Sean
Old Jan 15, 2009 | 07:15 AM
DuvalDino's Avatar
Default Re: Alignment Issues: Pic Request....
<ul><li><a href="http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&amp;Product_Code=KMAC-FL">K-MAC-Audi TT Rear Camber Kit-Full Kit</a></li></ul>
Old Jan 15, 2009 | 07:27 AM
JohnLZ7W's Avatar
Default this one?
<center><img src="http://images116.fotki.com/v693/photos/7/7305/63346/trailingarm-vi.jpg"></center><p>
Old Jan 15, 2009 | 09:40 AM
Russ Scott's Avatar
Default elongating those holes is a good idea, but I don't think it'll be easy
the plate is pretty hard and will be difficult to cut in place. It's somewhat labor intensive, but I think you'll need to pull it and take it to someone with a mill that can handle the hardness.
That said I'd rather run only adjustable lower arms and a milled plate, than upper and lower "adjustables". Having tinkered with changing the length of both arms, I'm not keen on it. It introduces so many variables. It's too easy to screw up your track width and thrust angle.
You don't need to go to all the way to zero toe. A little toe in is fine. Just be sure that both sides match and the thrust angle is as close to zero as possible.
dorsal900
Apr 8, 2008 02:53 PM
widstje
Mar 8, 2007 03:54 PM
juliem
Feb 24, 2007 07:49 AM
MocaptainTT
16
Dec 13, 2006 09:17 PM
Carrot TT
Jun 30, 2002 02:11 PM
