alternator replacement instructions 2000 Audi TT
Old Sep 6, 2010 | 06:44 AM
floresra's Avatar
Default alternator replacement instructions 2000 Audi TT
Does anybody have a link that can guide me on replacing the alternator?
Old Sep 8, 2010 | 11:50 AM
Kaidoi's Avatar
I did this 2 months ago following this link.
http://audi-diy.blogspot.com/2007/11...cement-tt.html
Good luck..
Old Sep 11, 2010 | 11:29 AM
floresra's Avatar
Great. Thanks. My car keeps dying if I don't drive it for a day, battery seems fine. Looking forward to taking a 2x4 to it... Thanks again.
Old Sep 11, 2010 | 11:46 AM
AudiMick's Avatar
That's not always an alternator problem.
You might have a low current drain on your battery. Check the current draw you should be at less than 50mA with everything off. The battery should last 4-6 weeks at that rate. If the current is higher check to see if something is staying turned on like a light bulb or the radio / amp. I had an ipod adapter that wouldn't go onto standby and took my battery down one a eek.
It's pretty easy to check an alternator, most auto parts places can do or just rev the car with a voltmeter attached. 13-14 volts when charging.
Daniel Monsi
Dec 11, 2017 09:34 AM
John J Szobocsan
Nov 19, 2002 09:58 AM
gtt
Sep 8, 2002 10:50 AM
