Another Offset question
Old Feb 19, 2003 | 07:07 PM
/\/\eTTalicA's Avatar
New Member
Default Another Offset question
According to an offset calculator, going from the stock 17x7.5 inch et32 rim to a 17x8 inch et35 rim,I will lose 9mm between the strut housing and the inner part of the rim. It will also extend 3 mm on the outer edge of the rim. Does that sound correct? Do I need spacers in this case, or is the 9mm loss negligable? Any help would be greatly appreciated.
Old Feb 19, 2003 | 07:09 PM
FasTTr's Avatar
That's less than 3/8 inch. Myself and lots of people have 18x8 35et without any issue.
Old Feb 19, 2003 | 07:27 PM
mcgilla's Avatar
Default 9.35mm should not be an issue...
6.35mm=1/2*0.5"*25.4mm/"<7.5 to 8.0" rim
3.00=et35<et32
9.35mm/25.4mm=0.37" closer to the strut...
Old Feb 20, 2003 | 02:26 PM
New Member
Default Re: That's less than 3/8 inch. Myself and lots of people have 18x8 35et without any issue.
thanks for the reply. I will prob order the Rondell R58's in 17x8. I am not sure if I want those or if I want to wait for the OZ SL's, which won't be available until mid march.
xtnct
Wheels & Tires Discussion
May 12, 2010 01:42 PM
maggio
May 3, 2004 07:57 PM
BSCA4
Apr 1, 2002 02:25 PM
ND4SPEED
Aug 31, 2001 09:06 PM
