Anyone bought this OBD Code Scanner?
Old Feb 17, 2006 | 10:56 AM
TTeleven's Avatar
Default Anyone bought this OBD Code Scanner?
I found this on ebay
Anyone have any info
Is it any good?<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;rd=1,1&amp;item=4614182 633&amp;sspagename=STRK%3AMEWA%3AIT">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;rd=1,1&amp;item=4614182 633&amp;sspagename=STRK%3AME
Old Feb 17, 2006 | 11:18 AM
Rocky-in-Connecticut's Avatar
Default You get what you pay for
these generic code readers will only pull and erase fault codes (if they work at all). They will not read valuable measuring blocks which one needs to diagnose the problems your fault code reveals. They will not be able to code control modules, perform readiness code tests, output tests, or actually give the code definitions.
There is only one solution that does all this. And beware of the cheap Ebay cables. I bought one and it did not work. Only one solution has worked right out of the package for me and enabled me to do everything I want.<ul><li><a href="http://www.ross-tech.com">Ross Tech Vag Com</a></li></ul>
Old Feb 17, 2006 | 02:41 PM
Seneb's Avatar
Default i have this one...
<center><img src="http://www.auteltech.com/images/pic2.jpg"></center><p>works great, has a booklet with all the codes listed. only thing is it doesn't fit snug, so you have to hold the connection while reading it.<ul><li><a href="http://www.auteltech.com/">http://www.auteltech.com/</a></li></ul>
P2WRTMR
VAG-COM Discussion
Aug 4, 2015 08:37 AM
mromanik
Mar 15, 2015 08:28 AM
Mx-3GSR
Audi allroad
Sep 5, 2008 06:40 AM
gdoyle
VAG-COM Discussion
Aug 4, 2004 12:05 PM
squidix9
Performance and Tuning
Apr 29, 2003 04:42 PM
