Audi TT AC Issues
But my ac is now blowing warm air...
I went to 2 places:
1) At Carmax they say i need to replace the ac compressor clutch and plates but not the compressor for 1400$
2) At my local garage they say they will replace the compressor which comes with clutch and plates for 800$
What should I do? Does the compressor comes with the clutch and plates? Who's right?
Thanks a lot in advance for your help!
Good luck. This may cost you a few bucks but AC work is fairly simple and anything thats wrong can be made good as new. They are great little cars. Enjoy!<ul><li><a href="http://www.worldimpex.com/search_by_model.html?mode=keyword&year=2001&am p;make_id=3&model_id=263&keyword=compresso r">http://www.worldimpex.com/search_by_model.html?mode=keyword&year=2001&am p;make_id=3&model_id=263
I took her to an AC shop where they first checked the system for gas leaks.
To do so they put a special gas, having the feature of getting coloured when in contact with air, in the empty system.
they actually found two leaks; the minor one in the compressor and the major in a valve (I guess was called isoentalpic); the latter was the one making the system not to work.
So they replaced the valve, fully serviced the compressor and checked all the seals.
I spent 400€+VAT (I'm Italian, by the way) that's to say around 280/300USD. The AC has been working great since then.
Ciao
Alessandro
You might want to check that Euro--Dollar exchange rate however. When we visited Rome a couple of years ago it was $ 1.35 per Euro. Now I believe it is more like $1.45 per Euro. But! If you ever wish to visit the Southern US I'd be happy to exchange you some dollars for Euros at your rate! :-)
Hope you don't mind my humor.
Y'all have a Great Day.
If the fans DO come on, then this fuse is OK and the issue is something else.
