BAMM problems update
1. Car had a hesitation at 4K aprox. 80% of the time. Very noticable when NOT WOT.
2. Computer readout for MPG(between speedometer and tach) was reading anywhere from 149MPG to ---MPG.
Problems found: After reading a post from 007TT, I found that some individuals have this exact same symptom (hesitation at 4K with the VW MAF sensor (#06A906461A). I have the VW sensor, so I replaced it with my OEM MAF sensor last night. The hesitation is completely gone. Last night, this morning, and afternoon runs were smooth as silk.
As far as the MPG readout. Below is a link posted by Russ Scott on how to adjust paramaters using VAG-COM that will bring the readings back in line. I have the OBDtool w/ the free vag-com software. I believe I will have to buy the full version to perform this function. I haven't pulled out my OBDtool yet.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1197705.phtml">https://forums.audiworld.com/tt/msgs/1197705.phtml</a</li></ul>
Also the MPG readout problem is directly related to the BAMM.
Personally, I am not a fan of the N75K and i believe it causes a lot more problems than most care to acknowledge....
The Boost Machine is a much better solution and is tunable...and in the end, it does not dial your boost way back...like the N75K.. IMHO
