Bose Issues
I picked up a mk1 Roadster, the audio system seems cobbled together.
Would I just be better off replacing the JVC head unit and rewiring the whole thing from scratch with a sub in the trunk? Or, is the sound processing from Bose worth trying to marry the right components to?
I keep waffling!
I kept the rear Bose woofers, and threw the Bose 6-CD changer in the trash. I used all the original car wiring except for routing RCA cables from the HU to the amp. On the Bose system the rear woofers are wired in parallel so I separated them. Also the Bose amp is only 2 channel. The front and rear speakers all share the same 2 signals but with a 4 channel amp now the rear woofers get their own signals.
It's a big improvement but I think I cheaped out on the speakers so I will probably upgrade those next.
I'm going to have everything run to add a small sub in the back if needed (sooo many rattles in the roadster, not sure if I could stomach the thump)
