A/C problem, using VAD Tool questions and help.
Old Jul 2, 2009 | 01:41 PM
turbo337's Avatar
Default A/C problem, using VAD Tool questions and help.
My a/c had been having problems and I've tried to use my friends VAD tool to help see if I can figure out my problems. My a/c is producing presure but it's at around 66 PSI. Which I've been told could just be a sensor or fuse that is blown or out.
I'm getting no cold air out and I have 8 DTC's Faults: but not that look to be an abvious clue..? Any help would be awsome if you see what could be causing the problem please post.
1.8L R4/5VT G 0003
DCTs:1
P/N: 8NO 906 018K
Coding: 06710, WSC: 01236
TRUWT28N211015985
AUZ5Z0Y9042337
17978P1570 163
Engine Control Module disabled [sporadic]
ESP 20 CAN V005
DTCs:0
P/N: 8N0907379E
Coding: 18446, WSC:01236
TT-KLIMAVOLLAUTOMAT D03
DCTs:1
P/N:8N0 820 043 A
Coding:00140, WSC:01236
00604158
Back Presure Flap Motor Position
Sensor-G113: open/short circuit to B+[Sporadic]
KOMBI+WEGFAHRS. M73D55
DCTs:0
P/N: 8N1 920 930 J
Coding: 07244, WSC:25168
TRUWT28N211015985
AUZ5Z0Y9042337
XXXXXXXXXXXXXXXXXXXXXXXXXx
HALDEX LSC ECC 0011
DTCs:1
P/N: 02D 900 554D
Coding:N/A, WSC:N/A
00526 027
Brake light Switch-F: implausible signal
taif_04
New Member Welcome Area
Dec 9, 2017 03:39 AM
fast4door
VAG-COM Discussion
Apr 10, 2006 06:22 PM
Mikael Palander
Oct 4, 2005 05:08 PM
s4gonebabygone
Jun 11, 2005 09:29 PM
zoomee
VAG-COM Discussion
Oct 10, 2003 05:03 AM
