Can changing out my DV to a Hyperboost throw a code or CEL?
Old Aug 2, 2002 | 06:43 AM
ND4SPD's Avatar
Senior Member
Default Can changing out my DV to a Hyperboost throw a code or CEL?
Do I have to be worried about installing this today?
Old Aug 2, 2002 | 06:45 AM
sTTanford's Avatar
Junior Member
Default nah. plug-n-play
if, for some weird reason, you get a CEL. i'd double check your installment, then pull your ECU for 5 minutes and let it reset.
if CEL is persistent... hmm, well then that sucks =) check hoses again? shrug.
Old Aug 2, 2002 | 06:47 AM
ND4SPD's Avatar
Senior Member
Cool.. Should I reset the ECU anyway?
Old Aug 2, 2002 | 06:50 AM
JazziTT's Avatar
Default The DV is not an electronic component. Just three hoses
Boost in/out and a vacuum source
Old Aug 2, 2002 | 06:53 AM
ND4SPD's Avatar
Senior Member
Oh, I know, but I meant should I reset the ECU so it can "learn" the new mod?
Old Aug 2, 2002 | 06:55 AM
Piker's Avatar
no real need to...just whack it in and drive!
Old Aug 2, 2002 | 07:01 AM
nansaidh's Avatar
Elder Member
don't you dare diminish my new-found mechanical ability! :-p
Old Aug 2, 2002 | 08:15 AM
joe@vwvortex's Avatar
Default If the hose on top of the DV is loose - it may throw a code
Usually a lean fuel trim bank in cylinder 1 - so make sure all connections are tight
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 2, 2002 | 08:32 AM
TTapsale's Avatar
I had a CEL lit for weeks. Changed the DV & cleaned MAF. No more CEL!
Old Aug 2, 2002 | 08:38 AM
TTapsale's Avatar
It will"learn" by itself!
