CEL problem
Old Apr 21, 2005 | 08:41 AM
seaTT's Avatar
New Member
Default CEL problem
I continue to have a CEL problem. The code pulled is system too lean. I bought a new VW MAF and installed it along with a **** and TTDA nad 4 bar FPR 2 weeks ago. Since then, the CEL has come on twice again with the system too lean code.
Any thoughts on what I should do next?
I brought it to the dealer before the **** and TTDA installation. Because of my SAMCO air intake hose, they would not look into the problem. I thought that changing out the MAF would fix the problem but it did not.
Thanks for any suggestions.
Old Apr 21, 2005 | 08:50 AM
RoberTT-WWCD's Avatar
Default Do you have the DTC number? It could be a vaccum leak or the...>>
temp sensor switch.
Old Apr 21, 2005 | 08:57 AM
TTagz's Avatar
Senior Member
Default they wouldn't look at it because of your intake hose? that's BS...
are you still under warranty? Bring up the Magnusson-Moss act, they'll take care of it.
Old Apr 21, 2005 | 10:00 AM
seaTT's Avatar
New Member
Default Why would temp sensor switch ...
cause the system too lean code? I'll get the DTC code tonight. Thanks.
Old Apr 21, 2005 | 10:07 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Not all 180's are compatable with the VW MAF....>>
I would order the Actual re-furb model...probably $80 or so....It's most likely still MAF related..
Old Apr 21, 2005 | 10:41 AM
seaTT's Avatar
New Member
Default I have a 2002 225 TTR ...
Sorry, I should have given you all the info.
GIAC-X chip, turn2 pulley, boost machine, Turbo XS diverter valve, Samco intake hose, TTDA, ****, and 4 bar FPR.
Thanks.
Old Apr 21, 2005 | 10:43 AM
seaTT's Avatar
New Member
Default I have also noticed that ...
ever since the CEL problem started, my gas mileage has been significantly worse. I used to be able to drive 350 to 375 miles off a tank of gas. Now I only get 300 to 330 miles.
Old Apr 21, 2005 | 11:34 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ooops....Sorry...VW MAF should be compatible..>>
But it seems lately with all the re-furbs hitting the streets, a small percentage are bad out of the box. Can you look at block 32 with a VAG? That would give some more specific info. Since it was happening before the ****-4 bar, it well could be something else. Replacing the $6 temp sensor would be a good place to start. Also power down the ECU (disconnect) to clear the adaptation tables which are probably triggering the CEL...
 Michael S. Palmer
Old Apr 21, 2005 | 12:42 PM
seaTT's Avatar
New Member
Thanks. I'll order temp sensor and check block 32.
Old Apr 21, 2005 | 03:42 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Temp sensor can be responsible for all kinds of erratic running......>
One of the major ECU inputs from which lots of settings to fuel, timing, etc are made..
CapitanMandingo
A4 (B7 Platform) Discussion
Feb 8, 2016 06:29 PM
djtnut
Mar 23, 2006 03:59 PM
mullarks
Aug 3, 2004 02:22 PM
Lloyd of the Rings
Oct 19, 2001 01:19 PM
