Central Lock control Module Replacement Procedure?
(my remotes stopped working due to water damage of the module I picked up a matching module from a junk yard and wanted to do it myself)
<img src="http://mk1tt.montebellopark.com/images/db25loc2ttr.jpg">
<img src="http://mk1tt.montebellopark.com/images/db25loc3ttr.jpg">
You will need a 10mm socket o nan extension. I used a 1/4" drive and small racket.
it's cramped, to say the least.
Remove the trunk floor cover, look at the link for a 'how to'
You will need to pul the panels from the back of the trunk to see where this module is located. You can get at a few of the screws this way, sorta.
Once you get the module removed, you can disconnect the cables.
it's *not* easy.
good luck<ul><li><a href="https://forums.audiworld.com/tt/msgs/1818671.phtml">Roadster Trunk cover removal</a></li></ul>
totally out on a limb here as far as the adaptation idea? thanks for any thoughts.
