check engine light
Old Sep 27, 2005 | 07:34 AM
https's Avatar
New Member
Default check engine light
I have had a check engine light on for the past month. I have brought the car into Audi 3 times, spent over $600 on a new MAF, hoses, clamps, and their outrageous labor since the labor is not coevered under my extended warranty. And once again - 2 days after I get it back home - that damn light comes on. The first time they said bad MAF. Then the hose came off the blow off valve. Then a large hose had a small pin hole in it. I feel like I'm getting the run around with Audi - any opinions on what I should do. The car runs fine. No hesitation, nothing - its just a non-blinking light.
Old Sep 27, 2005 | 07:42 AM
CWK_Marin's Avatar
Junior Member
Default Re: check engine light
Trade it in on another car.
Old Sep 27, 2005 | 07:47 AM
MadCityTT's Avatar
New Member
What is the error code you're getting?
Old Sep 27, 2005 | 07:49 AM
Braun9's Avatar
Default Undo the power cable from your car's battery for about 10 minutes and then hook it back up.
Sometimes the light will clear itself. Otherwise, get someone with a VAG-COM to read the code for you.
Old Sep 27, 2005 | 07:58 AM
https's Avatar
New Member
believe me - i've been looking at many other cars for the past month.
Old Sep 27, 2005 | 08:00 AM
https's Avatar
New Member
Default Re: What is the error code you're getting?
Not sure -I've had Audi do the work. I should probably get someone around Chicago that has a Vagcom to help me out....
Anyone have one in the Chitown area?
Old Sep 27, 2005 | 08:34 AM
msauve's Avatar
Default That only works to fix...
the very rare "I've been connected to the battery for too long" problem.
Old Sep 27, 2005 | 09:01 AM
jhoeppel's Avatar
Default I've got a ProDiag... Northside Chgo
email me if you're interested...
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 27, 2005 | 10:03 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Old Sep 27, 2005 | 01:03 PM
https's Avatar
New Member
Default Re: I've got a ProDiag... Northside Chgo
not sure how to email you....
but yeah - im interested.
marlena
Q5/SQ5 MKI (8R) Discussion
18
May 1, 2017 03:25 PM
Higher750
Jan 5, 2006 06:50 AM
SD_Quattro
14
Sep 7, 2005 09:57 AM
Orion5289
Sep 6, 2005 04:40 AM
HACK THS
Jul 28, 2002 04:46 PM
