Check engine light, cannot read code?
Old Apr 17, 2023 | 10:25 AM
wbnjr's Avatar
Default Check engine light, cannot read code?
My 2005 TT Roadster has a check engine light on. Unfortunately it will not let me read any error codes. It sees it as a 2005 but that is as far as it goes. My center readout also has gone blank. Any thoughts as to how to solve this. Audi dealer and two auto shops could not get it to read. I once heard you can touch post and negative battery leads to reset computer, any thoughts on that. Thx
Old Apr 25, 2023 | 09:55 AM
taga8's Avatar
Where are you at, recommend find someone with a vagcom to scan the can gateway. If you are in chicagoland, dm me, more than happy to help.
Old May 22, 2023 | 07:16 AM
wbnjr's Avatar
Default Still no luck, need to try to reset computer
I now have tried two more scanners (including OBEleven vag COM) and still no reading. Since I have had everything we can think of checked finding no problems, I now want to reset the computer to do away with check engine light) please advise how I might be able to reset.Thanks.
inQUOTE=taga8;25810364]Where are you at, recommend find someone with a vagcom to scan the can gateway. If you are in chicagoland, dm me, more than happy to help.[/QUOTE]
Old Jun 21, 2023 | 12:27 PM
wbnjr's Avatar
Finally scanned, 02 sensor, fixed.
Old Mar 1, 2024 | 09:27 PM
MRutten's Avatar
how did you get it to work? I have this problem too and cannot get scanner to read. Mine just says error. Everything is original no off brand speakers or cd players or radios added. I have had engine light on now for awhile. We removed the cluster panel in November as we were loosing lights on it. Car is in storage for winter and sending cluster panel in to be rebuilt this spring. Still need to solve the one scanner not working so wondering how you got yours to work.
rdynamix
May 10, 2005 12:23 PM
blueT28EnYcEe
Jun 3, 2002 04:29 PM
Dr.S4
Jan 12, 2002 06:23 PM
