Is a chip physically installed in the ECU when using a GIAC Flashloader?
Old Nov 18, 2005 | 01:40 PM
MaD MaTTer's Avatar
Old Nov 18, 2005 | 01:42 PM
joe@vwvortex's Avatar
Default No - it's loaded via the OBD port or directly into the ECU......
sometimes it's difficult to communicate to the ECU through the OBD cause it goes through the instrument cluster. In those cases they simply connect it to the ECU plug and do it that way.
Old Nov 18, 2005 | 01:43 PM
nikhil's Avatar
Default depends...
i think that initially cars needed to have a chip soldered in the ecu to work with the flashloader, but now the soldered chip is unnecessary.
Old Nov 18, 2005 | 02:13 PM
ePuFFy's Avatar
Default depends what year your car is...
mine's an early '01, so my GIAC chip was soldered in... if you a late '01 and on then it can be OBD2 loaded...
Old Nov 18, 2005 | 02:24 PM
Hmm - didn't know that early one's couldn't be flashloaded
Old Nov 18, 2005 | 02:46 PM
MaD MaTTer's Avatar
how could i tell if it early 2001 or late?
Old Nov 18, 2005 | 02:52 PM
ePuFFy's Avatar
Default look on your inner door well.. a sticker on there says your build date
and if you're like before June or July or something (I dunno) then you're an early one... like I don't have ESP, whereas other '01's do
Old Nov 18, 2005 | 03:04 PM
MaD MaTTer's Avatar
cars not with me but i do have ESP, does it mean its a late 2001?
 Michael S. Palmer
Old Nov 18, 2005 | 03:29 PM
ePuFFy's Avatar
Default I "think" so.. if you know your ECU type I think that's the best way of determining..
if you need to have the chip soldered or OBD2'd... either way, who really cares?
Old Nov 18, 2005 | 03:44 PM
JohnLZ7W's Avatar
Default No, only the very first MY2001s were missing ESP.
I think my car is an August 2000 build (October 2000 delivery) and it has ESP.
