Chip question??????
Old Aug 28, 2001 | 01:04 PM
Produce's Avatar
New Member
Default Chip question??????
When I first installed my giac chip it took about 4 runs before I felt boost(kicked in). About a week ago I unplugged the battery and I guess that reset the ecu and haven't felt the same boost since. Am I doing something wrong? Any suggestions??
Thanks
2001 TTR
Old Aug 28, 2001 | 01:44 PM
joe@vwvortex's Avatar
Default Did you do the throttle adaptation? If not you should
disconnect the battery or ECU and then put the key in the ignition and turn to the "on" position and wait three minutes, then start the car. It will take a few runs for it to fully adapt, but that should solve your problem.
Old Aug 29, 2001 | 07:12 AM
Produce's Avatar
New Member
Default Re: Did you do the throttle adaptation? If not you should
I did that. I just can't get it back to the original power that I had from boost.
robby
Aug 9, 2006 08:57 PM
minibike4
Aug 10, 2005 08:48 AM
faiz_twinzdaddy
Jun 1, 2005 12:39 AM
dimer
17
Aug 29, 2002 06:42 AM
Rob MacK
Aug 6, 1999 11:33 AM
