Cluster problems again...>>>
Old Nov 17, 2004 | 10:34 AM
Sully's Avatar
Member
Default Cluster problems again...>>>
Started the car up this morning and the instrument cluster flickered several times before...once again reseting the trip odometer and the time clock! I think this is a bad battery, not the cluster. What do all of you think out there. My mechanic said under load the battery is fine. I am suspicious.
Old Nov 17, 2004 | 11:09 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default How old is that battery again?
And test the resting voltage across the terminals after it's sat overnite. 12.2 or less and you need a new one..
Old Nov 17, 2004 | 11:15 AM
Sully's Avatar
Member
Default I suspect 4 years old. Not sure as I bought the car used.
What do you recommend for a cheap volt meter to test on my own?
Old Nov 17, 2004 | 11:17 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Damn! I think you need a new one!....>
You can get inexpensive digital voltmeters at radio shack from $10-20..
Old Nov 17, 2004 | 12:11 PM
OddOrEven's Avatar
New Member
Default Sounds like a "Cluster F@@K"..... ;^)
Miltary term for a situation caused by too many inept officers, cluster referring to the insignia worn my majors and LT. Colenels, oak leaf clusters.
Old Nov 17, 2004 | 03:30 PM
Kinetic0510's Avatar
Member
Default Darn you....
for making me laugh outloud =)
revisiTTed
Mar 31, 2008 01:46 PM
pudleboy1
Mar 14, 2007 09:44 AM
ZGTT
10
Mar 21, 2006 09:35 AM
Jetace1
Aug 7, 2005 04:24 PM
pianogrg3
May 12, 2005 05:29 PM
