DID problem
Old Nov 20, 1999 | 05:35 AM
Bill
Guest
Posts: n/a
Default DID problem
Day 2 of 180Q: Shut car off for an hour, restarted and DID had reset clock 8.5 hours off, set date to 7/1/98 and zeroed out all center displays except CD/radio. It also zeroed out my trip odometer. Help!
Old Nov 20, 1999 | 07:08 AM
Bob
Guest
Posts: n/a
Default Re: DID problem
Bill,
This information may also apply to the trouble you experienced with the clock/calendar. Several people have posted similar issues and been able to clear them by following this procedure.
Good Luck!
Posted by Steve L on 1999-11-18 23:43:53:
Back in September I asked the question about the strange behavior of the stereo info
on the DID...I got some answers, but none of them worked. Come to find out, one of
the postings was almost correct, except for a critical typo...it listed fuses 5 & 11
instead of the correct, 11 & 15. I pulled fuses 11 & 15 tonight and it worked like a
charm...my display is back to 'normal'.
Thank You!
Steve L
FYI: When this is done, the trip meter is reset to zero. As is the fuel mileage, elapsed
driving time, average speed (and clock/calendar as you said). A small price to pay!
Old Nov 20, 1999 | 07:11 AM
Bob
Guest
Posts: n/a
Default Clarification Re: DID problem
Although not explained in the referenced post, fuses 11 & 15 are pulled AND reinstalled.
Old Nov 20, 1999 | 08:01 AM
Bill
Guest
Posts: n/a
Fuses 11 & 15 are replaced, not just reinstalled, right? (nt)
Old Nov 20, 1999 | 09:34 AM
Ivan
Guest
Posts: n/a
Default I just pulled 11 & 15 and reinstalled. Problem solved for now...
I put the same fuses back in where they were. I pulled 11 first, then 15, then put 11 back in, then 15 back in.
I will be discussing this with my dealer on Monday, since they wanted to replace the whole cluster for something that is pretty evident is a software thing. What next, replace the ECU?
Thank you for the assistance. I will report back with my dealer's response and if the problem happens again. I don't want to have to reseat 11 &15 every few months, or we might as well call it a Lucas!
Ivan
Old Nov 20, 1999 | 11:45 AM
Bill
Guest
Posts: n/a
Default Reinstalling fuses 11 & 15
Thanks, Ivan. My salesman is due here at 5:30. He's checking this with their techs. I'll let you know.
Old Nov 20, 1999 | 09:01 PM
ivan
Guest
Posts: n/a
Default followup: instant fuel mileage did not work until I turned display off and on...
by tapping the reset button on the right stalk.
Everything else worked, tho.
What else have I reset that I can't see.
BTW, the Z8 in the new Bond movie is way less cool than my TT. They should have used a TTS Roadster. I was underimpressed.
Ivan
GalanTTe
9
Nov 9, 2001 01:50 PM
PHANTTOM
May 14, 2001 10:47 AM
FasTTspek
Oct 27, 2000 11:41 PM
Jason
Dec 28, 1999 11:33 AM
Steve L
Nov 19, 1999 02:56 AM
