DV flutter question.......
<img src="http://images19.fotki.com/v381/photos/6/645139/4513462/vtda040-vi.jpg">
Thanks to the VTDA you can hear things you never did before. I noticed a slight DV flutter with the Greddy RS in Relo today, slight 3 pulse flutter. I did some searching and found a post by Steve saying usually too tight a spring tension can cause flutter, and some posts that just said some do some don't. So I turned my adjustment 1/4 turn toward soft, and it is now smooth as silk, nice slow, continued release.
Could a 1/4 turn actually make an effect like that or could it have been slightly stuck or could the colder weather cause a slight flutter and the fact that it was warmer, made the flutter go away.
Thanks.
BTW, it was setup with the inner spring out and 4 turns toward hard
