Electrical problem
Old Jan 28, 2009 | 04:08 PM
leafs88's Avatar
New Member
Default Electrical problem
I've had this electrical problem for a few months now and I have no idea what it is. Fuse #23, which is "Sidemarker and taillight, left" blows usually as soon as I turn the headlights on. If it doesn't blow right away, it'll blow after a few minutes of sitting there or will blow as soon as I start driving
The dealer has had it for a combined 5 entire days and they gave up on it. They put a new fuse in and told me to come pick it up and of course their fuse blew as soon as I turned the headlights on.
I had it to an independent auto shop specializing in eletrical and they gave up on it after 2 days. Same thing, put a new fuse in which it blew in about 2 minutes.
The last two months I've been driving in the dark basically. The gauges lights and all the button lights are out. My left taillight and parking light are out. The taillight being the worse part of it.. I feel like I'm going to get pulled over at any moment.
Any ideas? Electrical and wiring is definitely not something that I really want to mess around with but at this point I think I'm going to have to dig in and fix it myself
Old Jan 28, 2009 | 04:50 PM
JustJeff's Avatar
Default Unplug the left tail light, put in a new fuse, and see if it blows still. If it does, it's not the
tail light (duh)
If it doesn't blow, take apart the tail light, remove the black bulb carrier, and inspect the bulb holders. They may be corroded, causing high resistance, causing a current draw=blown fuse.
Check the bulbs in this carrie to see if they are still well attached to the brass bases. Remove them all, inspect the bulb contacts.
Old Jan 28, 2009 | 05:44 PM
leafs88's Avatar
New Member
Forgot to mention.. I've done that already, its not the taillight
Old Jan 29, 2009 | 06:00 AM
JustJeff's Avatar
Default Check your brake light switch. I know, it doesn't sound plausible, but unplug it, try the lights....
start the car, drive it a bit, see if the fuse blows then.
BTW- there are 2 circuits on the brake light switch
leafs88
Feb 25, 2009 05:31 AM
LonelyTT
13
Jun 6, 2007 05:02 AM
KRW100
Audi 100 / A6 (C4 Platform)
Sep 3, 2002 05:09 PM
Onemax
May 13, 2002 02:25 PM
