Electrical problem....help (long)?
Old Jun 7, 2006 | 08:19 PM
germintor's Avatar
Default Electrical problem....help (long)?
This started a few months ago. I noticed that my 2001 TTR would sometimes reset the time (I have replaced the battery once in 2003 or 2004), and that the trunk release would sometimes require more than a push on the remote. Then, I had the 80k service. Everything fine according to the stealer. Three days after the service, the "check engine" came on. Because I had an argument with the stealer, I did not want to go back. Car seems to behave normally anyway. Today I go out to buy some groceries, and when I return the car is DEAD. By dead I mean, no sign of electrical activity when turning the key, no opening the locks with remote, etc. Call the tow truck. While waiting, opened the engine lid and checked out the battery and main fuses. Everything seems normal, but I notice the battery cable seems flimsy (as if it were broken near the battery where it makes a sharp angle). I also think (perhaps I imagined) that I heard a noise (like relays closing) when I touched that cable. Anyway, I close the lid .... and the car works again.
So, I am going to take a closer look at the battery cable. Perhaps a battery replacement is in order. And a visit to the stealer, maybe the "check engine" needs to be taken seriously.
Any opinion?
Old Jun 7, 2006 | 09:07 PM
whodkne's Avatar
Member
Default My guess..
Cable might need to be replaced, battery contact cleaned, etc. This situation could have caused a low power situation to cause the CEL. Best bet would be to actually check the CEL to see what that is and if it is related and check all connections to the battery.
Old Jun 7, 2006 | 10:39 PM
1T42T (aka ZZ CETT)'s Avatar
Member
Default Wait a second. That could actually be interpreted as a helpful response.
Am I on the right forum?
s
Old Jun 8, 2006 | 04:09 AM
GeTT da NeTT's Avatar
Default 2nd that. You might also consider the grounding mod, several write-ups and FOTKIs available thru
the search function. Good Luck!
Old Jun 8, 2006 | 07:19 AM
whodkne's Avatar
Member
It was late
whodkne's Avatar
Member
But it could also do nothing
Old Jun 8, 2006 | 07:23 PM
germintor's Avatar
Default Thanks, but...
what is a CEL?
Old Jun 8, 2006 | 08:32 PM
whodkne's Avatar
Member
Default Check Engine Light... take it to a dealer or Pep Boys (or similar) and get the code pulled from the
engine to know what kind of error you have.
 Pouria Savadkouei
 Michael S. Palmer
morris39
Audi A3 / S3 / RS 3 MKII
Jul 11, 2018 10:45 AM
Rellmlb53
Dec 30, 2017 02:39 PM
Xenon
Q5/SQ5 MKI (8R) Discussion
Jan 9, 2012 10:14 PM
tt-3
Nov 22, 2004 01:50 PM
