Electrical Problems Update(Central locking)
The roadster has a small catch tray and drain on either side near the hinge. The dealer suggested these had gotten clogged and that water had shorted the controller. He was almost right.
Shining a flashlight on the drains I could see water in both of them(and it hadn't rained in several days). I took some stiff wire and carefully cleared the drain.
Water had been overflowing the plugged drain and flowing under the carpet panel in the top well into the area where the contoller module is. I don't think the module actually got wet due to its location and covering. My best guess is that the accumulated water vapor got onto it or the connectors and is causing a short somewhere or has blown the module. I now have some functionality(auto window up/down) that had been broken but the gas cap and trunk buttons still don't work so I'm hoping it's just a short.
I've put a dehumidfying tub in the car and am letting it all dry out. I'm hoping to get the module connectors off this weekend to clean and dry them but it's a very awkward location. If that fails I'll replace the module, assuming I can get it out.
-Kevin
I think you're right about the through the trunk route, but it aint gonna be pleasant...unless you're a midget =)
