Engine codes
Old Mar 5, 2005 | 01:53 AM
JustAdam's Avatar
Default Engine codes
How do I find my engine code?
I looked under the hood and someone told me that it was stamped on the block. The only thing I can see that is stamped says "AMU" Is that an engine code?
I thought they were AWW and AWP
Also, what is the difference in coil packs between revision L and the latest "E" version?
From the looks of it I think I need the L version but I want to know if there is any difference between the 2 - or can I use either?
ecs states that I need the engine codes so I get the right part, which part do I need?
The coil packs were from ecstuning.com.
I have a 2001 TTQC 225 but the sticker under the hood says that it was manufactured in 2000 - is it a 2000 or a 2001?
TIA
Old Mar 5, 2005 | 03:16 AM
blackfnTTruck's Avatar
Yes, AMU is a valid engine code as well as BEA, ATC, and AWP for the 1.8 version
Old Mar 5, 2005 | 03:34 AM
JustAdam's Avatar
Default Thank you, so which coil packs would I need?
Do I get the "L" or "E" version from ECStuning.com - do you know? Or can you tell?
According to the images on the site, it looks as though I need the "E" version.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=225HP&amp;mo del=TT&amp;submodel=Quattro&amp;category=Maintenan ce&amp;subcategory=Engine">See both here - about half way down the page</a></li></ul>
Old Mar 5, 2005 | 03:59 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I have an AMU code and my car has the "E" style paks on it..
Just look at them to tell. E's bolt down, L's are just slip ons.
Old Mar 5, 2005 | 04:04 AM
MarTT's Avatar
Default I have the same engine code AMU though build date is Feb 01 >>
and I just ordered the "E" paks through ECS. The part number is 06B905115E. When I received the paks the actual part number on the top has been scraped off from all 4 paks (strange). The part number is correct on the box though.
Old Mar 5, 2005 | 04:15 AM
JustAdam's Avatar
Default Great - then mine are "E" packs too .........
now we are like family ;-)
Old Mar 5, 2005 | 04:16 AM
JustAdam's Avatar
Default But on the bottom of the hood it says year 2000
and on my title it says 2001 - I am such a nOOb!
Old Mar 5, 2005 | 05:54 AM
MarTT's Avatar
Driver side door jam - check build date on the sticker.
 Michael S. Palmer
Old Mar 5, 2005 | 06:20 AM
02TTK04's Avatar
Member
I HATE when ECS does that. So f'n shady of them.
Old Mar 5, 2005 | 09:15 AM
JohnLZ7W's Avatar
Default The model year for a car usually starts in the previous calendar year.
So there are many MY2001 cars that were actually delivered in 2000. There will be lots of people buying MY2006 cars this year.
B8aruba
A4 (B8 Platform) Discussion
9
Sep 24, 2022 07:24 AM
Rhu21
Jul 20, 2010 04:42 AM
polishadonis
Nov 5, 2006 02:41 PM
vaughn-gotti
Aug 23, 2003 04:41 AM
93urs4
May 31, 2002 12:42 PM
