Engine tech questions
Old Jul 7, 2003 | 10:05 AM
TTommyB's Avatar
New Member
Default Engine tech questions
So I spent most of Saturday with my car up on jack-stands, all covers and the bottom skid plate removed, with my "Auto Repair for Dummies" close at hand. Perhaps I was tired of not knowing what goes on underneath the hood, or maybe it was some gentle ribbing from MyBlueTT, but I felt it was time for me to start understanding the the details of how my engine is laid out and how it operates. Also felt it was good prep for installing a boost gauge and oil temp gauge connections in a few weeks. I poked around for a while, noting the starting components, the coolant system, the engine block and the fuel injection, etc.
Anyhow, I came away with a pair of questions that I figured the good people here could answer:
1) on the bottom of the transaxle transmission, towards the front, and about 2-3 inches from where it is sealed to the crankcase there is an open hole, about a half inch in diameter (not threaded). Looking into this hole I could see a large gear with fine teeth. I'm curious what I was looking at, since I was surprised to find an open hole in the bottom of the transmission and a gear without any lubrication on it. Or is this the starter flywheel?
2) the oil filter. Looks like an absolute bitch to remove and replace. I searched the forums and read some postings on how, so I guess there is no need to answer this question. Unless someone has a tried-and-true method for easily doing this?
Old Jul 7, 2003 | 04:42 PM
Europa's Avatar
Default That gear is definitely the ring gear on the flywheel, for the starter to drive (as you suggested).
I dunno about the oil filter; I've never even seen it. It often makes me wonder why companies design the most common maintenance item in a way that makes it really difficult to remove.
Old Jul 7, 2003 | 05:11 PM
TTommyB's Avatar
New Member
Default Perhaps so you don't do the work yourself
and instead pay their mechanics to do it for you?
Old Jul 7, 2003 | 05:56 PM
Europa's Avatar
Perhaps, but even once they get good at it, it'll still take their techs more time.
Nullman
A4 (B9 Platform) Discussion
Jun 21, 2016 06:36 AM
Kugs11
S4 (B8 Platform) Discussion
14
Feb 10, 2013 07:11 PM
Slye A4
12v V6 Discussion
10
Dec 20, 2006 10:55 AM
deml0
10
Jun 6, 2006 04:32 AM
cmv045
Aug 12, 2003 06:35 AM
