Example of compression heating of air.
Old Apr 10, 2001 | 03:52 PM
john s's Avatar
Member
Default Example of compression heating of air.
<center><img src="http://im1.shutterfly.com/procserv?si=00002937301920010410233632839.JPG&ps=0 &rx=255&ry=239"></center><p>We all know the need for our air-to-air intercoolers. Here is a visual of compression heating of air. Compressor intake is on left. Compression ratio increases as you travel axially towards outlet. Air is heated from 75°F to 140+°F. Cooler looking standpipe is actually low emissivity metal.
P.S. White hot spot on left is bearing frying, bearing on other, hotter, side of compressor is ok.
Old Apr 10, 2001 | 04:42 PM
VorTTC's Avatar
New Member
Default Nice pic....thermographic inspection?
Pictures like this make it so much easier for people to understand how mechanical things work. Have you ever taken pictures like this of electrical connections? A loose connection generates a lot more heat and can be seen easily...can literally save you thousands of dollars in an industrial application. Looks like you probably do this for a living!
Regards,
donromani
11
Dec 24, 2009 06:52 PM
20VT90q
Audi Original "S" Cars
Apr 28, 2008 04:06 AM
Dead
May 18, 2002 11:23 AM
joe@vwvortex
10
Aug 3, 2001 10:44 AM
